399 Users Online (16 Members): Show Users Online - Most ever was 3914 - Wed, Aug 26, 2026 at 4:53:14 AM
Forums >> Revit Building >> Technical Support >> section views
Mon, Jul 19, 2010 at 9:56:12 AM | section views
Bimman
Bimman Avatar
1 Stars: 2 Votes
I have just begun to lay in sections in my project and in the place in the marker where it states where the section was taken from is referenceing the wrong sheet.  It reference's my demo sheet AD-200, when the actual view is on sheet AE-103.  Any ideas on why this would be happening.  My demo plan is set to show existing and demo, new construction. my floor plan is a copy that i renamed and is set to show existing and new, new construction. no matter what view i am in when i make a new section it refernces my demo plan AD-200.  on revit 2011, no issues with 2010.
PWD
Mon, Jul 19, 2010 at 10:51:07 AM | section views
Bimman
Bimman Avatar
1 Stars: 2 Votes
here is a pic of what I am tlakomg about.
PWD
Mon, Jul 19, 2010 at 1:13:09 PM | section views
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
This is a known issue...I have not had it happen in 2011 yet, but I had it happen a bunch in MEP 2010.
In this case it was concluded that it was a Revit feature limitation with the way the referencing sheet parameter behaves and below there’s a more detailed explanation, based upon testing and research on this matter.
If you add sections and put them on a sheet,  Revit gets the detail number and referring sheet populated automatically.
If you have a client that requires the 3 part bubble, then you find yourself with having to show the detail number, the sheet it’s on and the referring sheet in the bubble.  Some callouts, being datum elements (section cuts, elevations, levels) can actually show up on more than one sheet.  When you put a view on a sheet, how does Revit determine the “referencing sheet” and “referencing detail”?
Simply put, it looks through your sheets.  The first sheet it finds that has the callout mark is the referencing sheet.  And that’s what gets put into your three part bubble.
Now, let’s suppose… you have an A2.1 sheet that is going to have your floor plan on, but you haven’t put it there yet.  You also have an A9.1 reflected ceiling plan sheet and you have put a view on.  I have a wall section that I am placing on an A5.1 sheet.  So I drag the view on there, and since the callout shows the “referencing sheet” info, it fills that in with A9.1.  Well, that’s not the view I wanted.  I wanted A2.1.  What is one to do?
Well, sometimes you just drag the view onto the sheet.  Drag the plan onto A2.1 and the referencing sheet of the section on A5.1 updates.
Sadly, sometimes that doesn’t work, especially if the sheet that you drag the desired plan onto is after the already placed sheet.  Then what do you do?
You jump through some hoops.  But let’s try to understand what appears to be Revit’s behaviors for the hoops.
  • When you place a view on a sheet, Revit looks through your sheets to see what the referencing sheet should be.  It also does this when you adjust the scope of your view.
  • Revit will only call a view/sheet  referencing if the callout is actively in a view, i.e. not hidden.
This is all based on observation.  The following are the hoops:
Find all the views that have a callout to the section (or elevation, etc, that you need to change the bubble)
Hide in view the callout in each view EXCEPT for the one that you want to be the referencing sheet
Activate the section (or elevation or whatever) and change the crop region ever so slightly.  Just drag it a little bit.  You’ll see the bubble update as Revit finds the only view on which you have the callout not hidden
Go back to the views from Hoop 2 and unhide the callouts.  Oddly, this will NOT update the section (or elevation, etc)
This will keep the referencing sheet set, unless you change the crop region for that view, then you have to repeat.
Ideally, the referencing sheet parameter would be a drop-down, and you could select what view/sheet you want, and possibly even build tags that can generate from a list of multiple views/sheets, but currently it is not the case.
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Mon, Jul 19, 2010 at 1:55:09 PM | section views
Bimman
Bimman Avatar
1 Stars: 2 Votes
OMG!!!!! i would have never figure that one out. thank you very much.  worked just as you described. have you had to use the 3 part callout in 2011 yourself, i am just wondering if it is still an issue like 2010 or maybe something in my application.
thanks again,
PWD
Mon, Jul 19, 2010 at 2:34:54 PM | section views
brettgoodchild
4 Stars: 17 Votes
Glad that worked for you and you were able to understand all that!!!
We pretty much use those callouts exclusively and have not had that problem happen in 2011 yet.
                             ~ Abraham Lincoln
create floor or other solid mass from Topo
Wed, Oct 5, 2011 at 8:47:05 AM
Refernce Sections
Thu, Jan 26, 2012 at 10:45:24 AM
Similar and Opposite call out heads
Thu, Mar 15, 2007 at 2:33:31 PM
Wall Section won't show in both plan and building section
Wed, Jan 29, 2014 at 6:52:25 AM
Building section callout visibility in intersecting views
Mon, Jun 16, 2008 at 12:40:58 PM
Page generation time: 0.1960
