84 Users Online (82 Members):
Forums >> General Discussion >> Revit Project Management >> Level trouble - Level Constraints
11 Posts No Rating |
I am having trouble revising the elevation of a single level with out moving all the other levels at the same time. I have a model of the 3 story building with a full basement. I have levels set up for each floor and the top of the footing. The building is an existing concrete frame structure, and I modeled much of the building using structural slabs and structural beams. Many of the walls and columns are constrained to the levels. Now I find that I need to move the top of footing up by 1', but when I move it up, all the other levels move up as well. If I copy an existing level, I can move that without affecting any other levels. Does anyone know why all the levels became constrained to each other and how I can get around this?
Try dimensioning the levels and check if the locks are closed.
YES, BE VERY CAREFUL OF OVERLOCKING YOUR MODEL. OVERLOCKING WILL GET U IN BIG TROUBLE.
Gebber, you were correct. I had a locked dim between the top of footing and top of slab levels. I thought I had checked that, but thanks for pointing me that way.
Changing model constraints from one level to another |
Wed, Aug 12, 2015 at 3:29:36 PM
Problem with level display |
Tue, Apr 6, 2010 at 12:58:24 PM
Level elevations |
Thu, Sep 11, 2014 at 12:54:39 PM
"Schedule Level" Parameter in Plumbing Fixture Family |
Thu, Jul 3, 2014 at 2:32:51 PM
create cellar level/floor plan below level 1 afterwards |
Mon, Jun 26, 2006 at 8:24:52 PM
