Forums >> Revit Systems >> Technical Support >> Export from Revit to Max
Mon, Jul 12, 2010 at 4:58:08 AM | Export from Revit to Max
archie456
3 Stars: 1 Votes
Whats the best way of exporting from Revit to Max - that also keeps all the material textures etc.
I was expecting this to be easy (as they are both AutoDesk products) - but I can export the model OK (tried DWG and FXB), but the materials texture maps don't come through)
Cheers.
Mon, Jul 12, 2010 at 1:17:18 PM | Export from Revit to Max
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
export as fbx from revit to max. Then check the folders that are created, asign them in max: customize/configure user paths/external files ... press add, browse where the folders of textures are, check the "add subpaths"...
then import the fbx file via file/import/import, edit theunits so they match your proyect. Once its on max, you still can group all, then scale to real size.
Revit to 3d Max FBX [ 1 2 ]
Wed, Dec 1, 2010 at 8:52:13 PM
17
3D Studio Max 7 data exchange problem
Wed, Apr 20, 2005 at 2:29:13 AM
Revit FBX causes 3DS Max to crash
Wed, Aug 10, 2016 at 6:02:27 PM
RPC and Camera's ??? --->>>Export to 3ds MAx
Tue, Oct 9, 2007 at 3:34:27 PM
Exporting walkthrough from revit to 3d max
Mon, Jan 6, 2014 at 3:39:53 PM
Page generation time: 4.4308
