Forums >> Revit Building >> Technical Support >> Legend Drawing Titles
Mon, Oct 3, 2005 at 10:36:44 AM | Legend Drawing Titles
hank
3.5 Stars: 3 Votes
When I bring a Legend View into a Sheet, It displays a "?" instead of the Detail Number as other Views do. The viewport properties dialog does not have a "Detail Number" option either. My custom Drawing Title Tag works fine with other view types (ie: plans, elevations) Any ideas?
Mon, Oct 3, 2005 at 4:36:51 PM | RE: Legend Drawing Titles
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Post the tag...
Mon, Oct 3, 2005 at 4:51:02 PM | RE: Legend Drawing Titles
hank
3.5 Stars: 3 Votes
Here it is... I'm sure you're on the right track - I probably screwed this up...
Tue, Oct 11, 2005 at 2:13:51 PM | RE: Legend Drawing Titles
hank
3.5 Stars: 3 Votes
Nevermind. I just had to manually edit it like text - no parameter to set - Thanks anyway.
Mon, Sep 24, 2007 at 6:45:31 PM | Legend Drawing Titles
twhisker
2.5 Stars: 5 Votes
I am having the same problem with 2008.  Legend view titles have a "?" instead of the view number and it does not appear as a parameter in the element properties.  It has a completely different properties list than a viewport for a drawing view.
When I drop in a schedule, it has no view title at all.  I would expect anything dropped onto a sheet should have a view title with a corresponding detail #.
Here is the custom view title attached.  Thanks.
Revit Architecture 2010
Can I have all my areas on drawing but only few values on Color fill legend?
Tue, Oct 30, 2018 at 7:32:26 AM
Legend Drawing # on Sheets
Wed, Dec 12, 2007 at 8:36:16 AM
Drawing Titles Single Line
Wed, Dec 3, 2014 at 7:25:28 AM
Legend Titles - no number
Thu, Nov 1, 2007 at 7:17:33 AM
Multiple Viewport Titles in same sheet
Wed, Jul 30, 2008 at 7:16:18 PM
Page generation time: 0.2491
