687 Users Online (44 Members): Show Users Online - Most ever was 3914 - Wed, Aug 26, 2026 at 4:53:14 AM
Forums >> Revit Building >> Technical Support >> Revit 2011 crashes on Rendering Appearances
Mon, Jun 7, 2010 at 1:50:39 PM | Revit 2011 crashes on Rendering Appearances
CVA0
All Revit software I have installed crashes when I want to create/change a materials Render Appearance.
In the ArchVision log I found the following error message:
"BEGIN 5872 Mon Jun 07 19:44:36 2010 "RPC API" The RPC API is contacting the RPC ACM.
LOG 5872 Mon Jun 07 19:44:36 2010 "RPC API" revoke licenses
WARNING 5872 Mon Jun 07 19:44:37 2010 "RPC Content Client" Unable to connect to the ArchVision Content Manager at the following address:127.0.0.1:14931Make sure that your RPC Content Configuration contains the correct address for your ArchVision Content Manager.You may need to check with your office administratorto obtain the correct information, or you can use the Scanfeature to locate the ArchVision Content Manager.
LOG 5872 Mon Jun 07 19:44:37 2010 "ArchVision Content Client" connection error == 10061
LOG 5872 Mon Jun 07 19:44:37 2010 "RPC API" revoke licenses
BEGIN 5872 Mon Jun 07 19:44:37 2010 "RPC API" RPC API scanning local paths....
END 5872 Mon Jun 07 19:44:37 2010 "RPC API" RPC API done scanning local paths.
END 5872 Mon Jun 07 19:44:37 2010 "RPC API" The RPC API is done contacting the RPC ACM.
It seems that the ArchVision Content client cannot contact the manager, which makes the program crash.
Haven't been able to find a solution so far.
Mon, Jun 7, 2010 at 1:59:09 PM | Revit 2011 crashes on Rendering Appearances
4 Stars: 206 Votes
Hi, see this: http://www.revitcity.com/forums.php?action=viewthread&thread_id=20232
and this: http://www.revitcity.com/forums.php?action=viewthread&thread_id=20346
Mon, Jun 7, 2010 at 2:13:13 PM | Revit 2011 crashes on Rendering Appearances
CVA0
Hi Typhoon,
This doesn't seem to be the solution to my problem. All the settings are correct. The same problem occurs in all Revit Arch, Structure and MEP.
Mon, Jun 7, 2010 at 2:16:45 PM | Revit 2011 crashes on Rendering Appearances
4 Stars: 206 Votes
Did you talk to Archvision or Autodesk about that?
Mon, Jun 7, 2010 at 2:30:00 PM | Revit 2011 crashes on Rendering Appearances
CVA0
I will contact Autodesk and/or ArchVision.
The thing is that I have been working fine with 2011 until now and thought it might be a minor problem.
RevitCity.com chat.. INSIDE OF REVIT!
Wed, Oct 19, 2011 at 2:50:01 PM
New in Autodesk® Revit® Architecture 2011
Mon, Apr 26, 2010 at 2:12:40 AM
Revit 2012 Crashes Random but everyday [ 1 2 ]
Wed, Feb 29, 2012 at 1:15:57 PM
15
Delete Document Asset Appearances
Tue, Feb 20, 2018 at 10:32:42 AM
Creating Families
Wed, Sep 24, 2008 at 5:06:16 PM
Page generation time: 0.7285
