39 Users Online (38 Members):
Forums >> Revit Building >> Technical Support >> Schedule Window Area
Hi, I need to calculate the window area in a schedule based on window length and width parameters but I'm stuffed if I can figure out how to type it up in the formulas. I would have though under calculated value something along the lines of Opening Height * Opening Width would be correct but apparently not. All assistance greatly appreciated Cheers B
Sounds right to me....Is you result Type an Area? - Has to be.
Formulas in Revit are name and case sensative. Width * Height would work as that is what the parameter names are unless you've added your own custom parameters. Define the calculated value to be an "area" as WWHub says. See the help file on formulas.
Tom www.reviteer.com http://twitter.com/Reviteer |
Curtain wall area in window schedule |
Tue, Jan 27, 2009 at 10:41:42 AM
Revit 2015 - Window Schedule, show "from area" |
Thu, Apr 21, 2016 at 8:48:57 AM
Revit 2013: Window to Wall Ratio Schedule |
Tue, Jul 15, 2014 at 8:47:20 PM
Window Schedule |
Fri, Mar 31, 2017 at 8:08:38 AM
WALL AREA AND SCHEDULE |
Fri, May 1, 2009 at 2:44:28 PM
