Forums >> Revit Building >> Technical Support >> Revit Callouts
Wed, Apr 21, 2010 at 10:04:47 AM | Revit Callouts
allenj41
I am using Revit Architecture 2010, and I created a floor plan with dimensions and details. When I went to make a callout of it for greater detail (the scale wouldn't fit on my sheets), it removed all of my dimension lines. Any idea how to get them to show in the callout view?
 Thanks for your help! Smile
Fri, Apr 23, 2010 at 7:35:16 AM | Revit Callouts
Notes, detail lines, tags, filled regions and detail elements ...in other words, all 2D elements, are view specific.  So, we you create a call-out, you can copy to clipboard any of these items you want from the parent view and then paste same place in the callout view.  This process also works in reverse.
NOTE: With dimensions and tags, the element being dimesnioned or tagged, must be in the view in order for these items to be visible when pasted.
Are Callouts Vew Specific?
Wed, May 12, 2010 at 3:56:06 PM
Visibility of callouts
Fri, Nov 11, 2011 at 3:04:48 PM
HELP! callouts are not visible!!
Sat, Feb 16, 2008 at 12:17:21 PM
CALLOUTS IN PLAN PROBLEM
Fri, Aug 17, 2007 at 9:08:56 AM
Callouts and Callout Sim Views
Thu, Sep 12, 2013 at 10:41:57 AM
Page generation time: 3.5458
