349 Users Online (19 Members):
- Most ever was 3914 - Wed, Aug 26, 2026 at 4:53:14 AM |
Forums >> Revit Building >> Technical Support >> Need to make adjustable detail component for spray on insulation--see image
5 Posts No Rating |
I am detailing spray foam insulation and need a detail component that is adjustable--definitely for length and ideally for width--though not necessary. I've toyed with the idea of visibility parameters and repeating components but that limits it to fixed predetermined lengths, when I would much prefer something that stretches on an instance basis. The jagged edge doesnt necessarily need to be quite so...jagged, so in other words if creating a repeating pattern is the solution then that would be acceptable--I just don't want the pattern to have to dictate the length of the component. Any ideas/advice? Thanks!
You might ry a repeating detail where the rough face starts and ends in the same vertical plane and that has invisible lines top and bottom. You could assign a depth (type) parameter and have multiple types.
5 Posts No Rating |
Just did that, and used "Maximum Spacing" for the layout parameter, so it adjusts to whatever I want. Thanks!
Members: | 2188042 | Objects: | 23399 | Forum Posts: | 152455 | Job Listings: | 0 |
