Forums >> Revit Building >> Technical Support >> Generic Annotation Labels
Thu, Sep 22, 2005 at 3:14:08 PM | Generic Annotation Labels
smh
I have a question about how to associate a multi-lined value in a parameter. For example, I want to create a label for a clients address that includes the value Address1 Address2 City, State Zip -- on seperate lines as shown How do I enter that in as the value of the parameter-- or is there another way to create this label that will be applied to a titleblock. Thanks for any help!
Thu, Sep 22, 2005 at 4:30:19 PM | RE: Generic Annotation Labels
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You can either set the parameters to wrap to a new line after a certain length of text. Or you can force it using the method i've previously posted using the current project address field, typing the text in there and then pasting it into the properties window for the appropriate field of the titleblock. This forces multi-line where you require.... Bit of a workaround but it works.
Generic Annotations - Hiding Labels
Wed, May 16, 2007 at 4:17:31 PM
Generic Annotation with Family Category based parameter
Mon, Sep 16, 2013 at 7:18:15 PM
Generic Annotation- Controlling order of labels
Fri, Apr 11, 2014 at 7:32:21 AM
Nest Generic Annotation in Detail Component
Wed, Mar 17, 2010 at 7:18:22 PM
Generic Annotation symbol
Mon, Dec 5, 2011 at 4:02:48 PM
Page generation time: 1.7742
