11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> floors showing through the elevation.
2 Posts No Rating |
I am using a gernic floor and it shows through the elevations and in 3D. What am I doing wrong?
Is your floor defined to the outside of the wall? Is your view set on wireframe? Is your wall set to be transparent? Probably the first item listed above.
2 Posts No Rating |
I moved the floor to the inside of the wall and that did the trick. When I draw a floor, should I always be using the inside surface to locate the floor? Thank you very much for your help!
Model it like you build it. If the wall is a curtain wall and runs completely past the floor, then end the floor inside the wall face. If the floor bears on the wall or the wall is built on the floor but the exterior skin goes past, then model it taht way.
Elevation Markers: visible on all floors |
Mon, Nov 7, 2011 at 12:24:27 PM
WALL JOIN PROBLEM - Ends showing in 3D and Elevation View |
Tue, Jul 22, 2008 at 9:38:24 AM
Floor tag - elevation spot |
Thu, Apr 27, 2017 at 7:20:09 AM
Walls from multiple floors above showing in site plan |
Wed, Oct 3, 2012 at 9:23:52 PM
View Name showing up in Elevation Tag |
Wed, Feb 29, 2012 at 6:53:36 PM
