19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> Roof Structure
4 Posts No Rating |
I need to know the easiest way to create roof structure such as rafter, purlin, so on...
Thank you
are you talking about creating the member itself or the roof framing? I assume the roof framing so...
1.cut a section through the roof you created, I normaly just use a 16mm or 25mm roof sheeting.
2. draw a reference plane under the roof sheeting and name it whateveryouwant
3. back to roof plan and change your work plane to the reference plane you created b 4.
4. I use the "beam system" and draw your primeter, load your member profile and finish sketch
works great for skilion roof, for a hip roof, you will need to do the same to each side from step 1
it's a bit of work but once it's done, it's done.
if you are talking about the member iitself, just use the generic or structural template to create the family.
good luck HTH.
how to dreate a double gable ended roof on a square structure???? [ 1 2 ] |
Fri, Mar 13, 2009 at 7:42:49 PM
25
Additional Roof will not attach to original roof |
Fri, Jun 7, 2013 at 7:56:40 AM
Sloping Roof Structure |
Mon, Dec 17, 2007 at 7:05:09 AM
adding crickets to a sloped roof structure |
Mon, Oct 16, 2017 at 9:28:29 AM
roof structure |
Wed, Jun 14, 2006 at 3:28:02 AM
