39 Users Online (37 Members):
Forums >> Revit Building >> Technical Support >> Family type for connector that needs to rotate
2 Posts No Rating |
Hopeful for help, I'm looking for the right family category type to model a 6 point hub connection. I'm working on a dome project that require 60 differant versions of the hub. The 60 connection also need to rotate (tilt) from verticle in two directions, and be able to have beams connect to the ends/faces of. Using Revit Architecture 2010, not Structure. -John
Turn off always vertical in category and parameters.
2 Posts No Rating |
Tried that. Turned off the verticall in all the families and reloaded into project. Error message says that it can not rotate object into possition. Any other ideas? -John
Family with variable "System Type" for a connector element |
Thu, Mar 10, 2011 at 10:32:32 AM
Family Editor - Duct Connector |
Mon, Jun 16, 2014 at 1:52:01 PM
create new connector system type |
Fri, Sep 18, 2009 at 3:55:39 PM
Duct Connector Not Visible?? |
Thu, Feb 17, 2011 at 11:41:00 AM
Connector Size Limitations |
Wed, Dec 19, 2012 at 1:11:10 PM
