576 Users Online (27 Members): Show Users Online - Most ever was 3914 - Wed, Aug 26, 2026 at 4:53:14 AM
Forums >> Revit Systems >> Technical Support >> Fill pattern upside down???
Sun, Mar 14, 2010 at 11:25:33 AM | Fill pattern upside down???
wdesign
I am applying a shake fill pattern and for some reason it is coming in upside down. What would cause that and how do I fix it?
Regards,
Darrin
Sun, Mar 14, 2010 at 11:27:51 AM | Fill pattern upside down???
wdesign
Got it ...
Thu, Jun 16, 2011 at 10:54:11 AM | Fill pattern upside down???
iamian33
iamian33 Avatar
so what did you do to fix this?  I am having an issue with fill pattern orientation (align w. element), perhaps your resolution might help me ...
I've tried Drafting and Model patterns, I've tried all 3 options in the pattern orientation, but I cannot seem to get this pattern to align with element.
What did you do to correct your issue?
Ian
Ian Shafer
Principal Consultant
True North S&F Consultants
Thu, Jun 16, 2011 at 11:02:06 AM | Fill pattern upside down???
Model patters can be rotated and when used with a material tahat has a pattern, they will match.  I'm sure that the previous poster had a material with an assigned model pattern which he rotated.
Thu, Jun 16, 2011 at 11:07:57 AM | Fill pattern upside down???
iamian33
iamian33 Avatar
Thanks WW but I am dealing with a Glu-Lam material for my beams.  There are 'several'.  Will I have to manage them individually?  That's what I thought the 'align w element' option was for ...
Ian Shafer
Thu, Jun 16, 2011 at 11:25:21 AM | Fill pattern upside down???
Aligned works with items like coarse fill for walls.  I have never found it to work with detail elements.
Thu, Jun 16, 2011 at 11:35:51 AM | Fill pattern upside down???
iamian33
iamian33 Avatar
no, not a detail element.  I have a modle with glu-lam beams.  I have imported these from the revit library for use in the model.  for the sake of graphical clarity, I applied a surface pattern (horizontal lines at 2") so that the beams will show in the interior elevations and rcp.
However if the beam is oriented/rotated, the hatch pattern remains the same and does not align the the beam (element).  All this is in the model (3D) and not a detail (2D).
Ian Shafer
Sweep problem
Thu, Dec 20, 2012 at 7:22:20 PM
Inserted Image prints upside down
Sun, Nov 13, 2016 at 9:42:45 PM
Solid Drafting fill pattern
Tue, Jun 23, 2015 at 1:35:01 PM
Fill Pattern Naming
Wed, Feb 1, 2017 at 10:19:41 AM
Stray Lines in custom Revit fill pattern
Mon, Jul 8, 2013 at 8:02:44 AM
Page generation time: 0.1825
