Forums >> Revit Building >> Technical Support >> Ceiling Plan locked cannot add dimensions to it
Thu, Mar 4, 2010 at 6:30:06 PM | Ceiling Plan locked cannot add dimensions to it
quinn
We have an rcp layout that you can add dimensions too.  We created a callout for it. Inside the callout view it wont allow us to select anything in it. The lights and registers are there cause we can grab them in the rcp   but in the callout its like they dont exist we can see them but we cant select them and because the families dont register we cant dimension anything in the view.  There are no worksets other than the default one, no options, the view range is set the same as the rcp.  Any ideas of what is going on?  I made multiple callouts from the rcp and none allow us to select anything in them.
Fri, Mar 5, 2010 at 7:53:09 AM | Ceiling Plan locked cannot add dimensions to it
What version are you in?
I can't recreate the problem - everything works here.  Standard ceiling plan - callout is also a ceiling plan.
Fri, Mar 5, 2010 at 9:16:18 AM | Ceiling Plan locked cannot add dimensions to it
quinn
We are using 2010.  I have tested a sample file and the callout works fine in there. This particular project the callouts for the rcp do not and only from the rcp the floor plan etc are fine just the rcp callouts.
Fri, Mar 5, 2010 at 10:27:11 AM | Ceiling Plan locked cannot add dimensions to it
quinn
WHat is very strange is when i set my view to wireframe instead of hidden line i can actually grab the objects.
Recessed Lights in Sloped Ceiling
Thu, Dec 13, 2007 at 10:23:28 AM
Adding a ceiling
Mon, May 11, 2009 at 1:18:58 PM
Add Ceiling Height in Room Schedule
Mon, Nov 19, 2012 at 9:38:54 AM
Adding Text Below Dimensions
Sat, Mar 3, 2007 at 10:55:04 AM
11
Please help with Ceiling Plan
Sat, Mar 21, 2015 at 7:20:04 PM
Page generation time: 0.5711
