Forums >> Revit Building >> Technical Support >> Levels Missing in Elevations
Fri, Feb 12, 2010 at 2:17:52 AM | Levels Missing in Elevations
EssG
Rev 2009 Arch.
Hi
I opened a new project in my work template and started drawing...when I went to Elevations there are no level markers at all in any of the elevations so I cant change their values.
I only have a site and level one plan standard in my template and usually create other plans as I need them..and even some of them are missing in the view>new>plan command, even though all the  different levels show up in my "constraint" drop down boxes. I have checked that they are not "hidden in view" and that in Vissabilit/graphic overide dialog all boxes are ticked.
Any help would be greatly appreceated
Thanks
Fri, Feb 12, 2010 at 4:15:22 AM | Levels Missing in Elevations
Kardiff
5 Stars: 3 Votes
I had a similar problem before and checked the forum and found this solution
.Create a scope box around your plan      .open up an elevation     .create a new level     .highlight the level and select all instances.element properties and attach / asisgn (can't remember exactly) to scope box
all your level will now be visible in that view.you can now delete the scope box and the new level
- Just trying to help out while I wait in the office for my renders to complete
www.danrossiter.co.uk
Fri, Feb 12, 2010 at 5:08:46 AM | Levels Missing in Elevations
EssG
Thanks for that Kardiff...it was a win!!!
Thu, Aug 25, 2011 at 10:48:21 AM | Levels Missing in Elevations
echo1
Old thread, but thanks.  It still works.  :-D
Tue, Dec 4, 2012 at 5:31:44 PM | Levels Missing in Elevations
raja15
Thanks @Kardiff!
Solution still works in 2012 in Revit 2013.
Smile
Mon, Aug 26, 2013 at 12:20:14 PM | Levels Missing in Elevations
Corleone07
Thanx Man !!!   Bravo !
Section Tags missing (again)
Wed, Aug 26, 2009 at 10:50:38 AM
Levels missing Revit 2012 [ 1 2 ]
Mon, Sep 28, 2015 at 3:29:41 PM
19
elevation levels missing
Mon, Feb 23, 2009 at 3:09:03 PM
Levels are missing - I tried all solutions on forums no result
Wed, Jan 30, 2013 at 10:57:43 AM
Phaseing Levels
Fri, Oct 15, 2010 at 6:23:50 AM
Page generation time: 0.3408
