Forums >> Revit Building >> Technical Support >> 3d view matches the plan view
Tue, Feb 9, 2010 at 1:27:23 PM | 3d view matches the plan view
diesellam
Let's say I set up the floor plan the view the way I want it.  (Certain elements are deleted.)
While I'm at the floor plan view, when I click on the view, 3d view, everything shows up.  What's the reason for it?
Is there a way that the 3d view matches exactly how it looks like in the floor plan view?
Tue, Feb 9, 2010 at 1:34:22 PM | 3d view matches the plan view
If you deleted a model element from the project then you deleted it from all views where it may have been shown.  You can control views using view templates but as far as I know, view templates can not be transfered across different view types.  Therefore, you have to set VG and VP properties for each view type.
Tue, Feb 9, 2010 at 3:00:31 PM | 3d view matches the plan view
diesellam
Thanks, now it makes sense.
Plan view levels
Tue, May 5, 2009 at 3:15:03 PM
Sections not Showing in Plan View
Mon, Oct 28, 2019 at 4:42:02 PM
Internal Shadows in Plan view
Thu, Sep 14, 2006 at 1:17:38 AM
Beam not showing in Plan View no matter what I try
Thu, Nov 5, 2015 at 4:29:31 AM
PLAN REGION VIEW DEPTH CHANGE OVERALL FLOOR PLAN
Fri, Aug 29, 2014 at 1:27:29 PM
Page generation time: 1.5702
