Forums >> Revit Building >> Technical Support >> Ceiling Height
Tue, Jan 5, 2010 at 5:44:32 PM | Ceiling Height
alex8605
The default ceiling height seems to be 8'.  Can this default be changed?  I know how to change the instance properties, but not the type properties.
Wed, Jan 6, 2010 at 6:43:44 AM | Ceiling Height
Your HELP is a great resource for questions like this.  Do a search of your HELP using "ceiling" and you will find the answers to these questions and much more.
Wed, Jan 6, 2010 at 10:57:23 AM | Ceiling Height
alex8605
I spent quite a bit of time searching HELP, but haven't found an answer to this.
Wed, Jan 6, 2010 at 11:15:33 AM | Ceiling Height
In the HELP section: Sketching a Ceiling  it says:
4. Click Ceiling Properties.
5. In the Instance Properties dialog, designate the type of ceiling and its properties, and click OK.
One of those properties is the height offset from level... when you set that, that will now be your default ceiling height...until you set it again.
Wed, Jan 6, 2010 at 11:42:38 AM | Ceiling Height
alex8605
Thanks for your help.  I found how to change the height in the Instance Properties, but I thought there must be a way to change the default.
Wed, Jan 6, 2010 at 11:46:49 AM | Ceiling Height
coreed
coreed Avatar
4 Stars: 16 Votes
if you set that in the ceiling properties before placing a ceiling it will be your default.
hth
Edited on: Wed, Jan 6, 2010 at 11:47:25 AM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
locking height of family to ceiling height?
Mon, Apr 27, 2009 at 5:29:03 AM
Ceiling height column problem in schedules
Fri, Dec 7, 2007 at 10:23:16 AM
Room Name w/ manually entered Ceiling Height
Mon, Jan 19, 2009 at 3:50:30 PM
Add Ceiling Height in Room Schedule
Mon, Nov 19, 2012 at 9:38:54 AM
Room schedule with ceiling height
Thu, Jan 18, 2007 at 3:46:21 PM
Page generation time: 0.2243
