Forums >> Revit Building >> Technical Support >> Change Placement of Elevation Tag in Different Views
Fri, Dec 11, 2009 at 6:31:14 PM | Change Placement of Elevation Tag in Different Views
chowlowhammond
I have a building that gets smaller & smaller the higher it goes.   This causes a problem with my elevation tags, because I set them relative to main floor (the largest plan), but then they are way off in outer-space in my upper floors (the smallest ones).   Is there a way to move the elevation tag for a specific view, & not have it move throughout the entire model?  These are annotations really, & should not be treated like model elements, right???
Thanks.
Door tag placement??
Thu, Jun 8, 2006 at 11:44:11 PM
Elevation Tag Location
Tue, Dec 7, 2010 at 4:56:00 PM
Revision Cloud - Tag on placement??
Wed, Feb 20, 2013 at 8:44:05 AM
Elevation Tag - Leader Problem
Thu, May 17, 2012 at 5:48:20 PM
location of the elevation tag and section tag
Tue, Aug 10, 2010 at 10:07:10 AM
Page generation time: 0.7019
