Forums >> Revit Building >> Technical Support >> 3d view misaligned with viewport when put on sheets
Wed, Dec 2, 2009 at 8:36:40 AM | 3d view misaligned with viewport when put on sheets
ZSPTurbo
I don't know why this is happening. I cant get the viewport and the view edges to align. Whenever I move something, crop something, whatever... the misalignment follows. HELP!
Image attached:
Edited on: Wed, Dec 2, 2009 at 8:49:08 AM
Wed, Dec 2, 2009 at 8:41:12 AM | 3d view misaligned with viewport when put on sheets
Not sure what you are asking.  The view title can be moved independently of the view.
Wed, Dec 2, 2009 at 8:48:32 AM | 3d view misaligned with viewport when put on sheets
ZSPTurbo
Im still new to revit, so sorry if my explanation is unrefined. The highlighted box is the "viewport" but when I activate view, the box to the lower left is what it lets me work in.. I believe it is the boundry of the view (the edges of the camera cone).
Wed, Dec 2, 2009 at 9:26:05 AM | 3d view misaligned with viewport when put on sheets
When you have multiple views on a sheet, their locations may overlap.  Use the tab key to select the view you want to open.
Wed, Dec 2, 2009 at 10:29:56 AM | 3d view misaligned with viewport when put on sheets
ZSPTurbo
THey are not separate views. It is the same view.
Wed, Dec 2, 2009 at 10:52:55 AM | 3d view misaligned with viewport when put on sheets
Sorry but they are not.  You can not place two copies of the same view on a sheet.  Both are 3D views and when you select something in one view, that same element will highlight in the other view but you have two seperate views.
Wed, Dec 2, 2009 at 11:44:43 AM | 3d view misaligned with viewport when put on sheets
ZSPTurbo
It was a single view. the problem was that it was displaying the viewport box offset from the actual viewport. A lab tech figured it out but didnt have time to explain it to me. He just made a new sheet and that new sheet didnt have whatever setting was making it all screwey.
Draw Order of Viewport on a sheet
Wed, Dec 16, 2009 at 4:35:58 PM
Align Floors on Multiple sheets
Wed, Nov 17, 2010 at 3:26:28 PM
Is their a way to change the Viewport referencing?
Wed, Sep 21, 2016 at 3:16:25 PM
Viewport Text
Wed, Mar 9, 2016 at 10:00:08 PM
Default viewport type R14
Tue, May 20, 2014 at 4:16:06 PM
Page generation time: 1.3600
