47 Users Online (46 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> Newbies >> custom stacked wall
Tue, Dec 1, 2009 at 11:46:29 AM | custom stacked wall
Crosscad
Hi I am working on a project that has a stacked wall.  Brick at the bottom and wood siding at the top.  I would duplicate the stacked wall in the imperial template and just change the materials but I'm not sure where to go to find or load siding so I can choose it as a type.  Any help would be greatly appreciated!!
Thanks.
Wed, Dec 2, 2009 at 7:26:29 AM | custom stacked wall
If you don't see the material siding, then you will have to create it using the appropriate material.  Most of use do not use a modeled shiplap siding and let the material setting show it correctly when rendered.
Mon, Dec 7, 2009 at 12:59:22 PM | custom stacked wall
Crosscad
I saw in a file where I had previously used a siding wall the structure of the wall was listed as 6", and the material was listed as Finishes: siding / clapboard.  Does this mean it was a 3-D "finish" and not actually a structural siding?  I guess as long as it looks correct on my 3-D's and my walls schedule correctly it doesn't matter right?
Mon, Dec 7, 2009 at 1:04:58 PM | custom stacked wall
Right.... the wall thickness includes siding in the definition - the material renders correctly in 3D but in 2D views, it is represented as simple hatch pattern - parallel lines.
Tue, Dec 8, 2009 at 10:51:41 AM | custom stacked wall
Crosscad
Can I copy the Finishes: Siding/Clapboard from the drawing its in to somewhere in Revit 2010 so I can use it on the stacked wall I am trying to create?  Where do I copy the "Finishes" from in the program and where do I paste it in Revit 2010 to use on my walls?
stacked wall line visable on the wrong side?
Wed, May 6, 2009 at 10:51:58 AM
Can't Put Curtain Wall Inside Stacked Wall??????? Help Needed
Thu, Jan 24, 2013 at 8:06:06 PM
Scheduling of Stacked Walls
Tue, Aug 18, 2009 at 2:16:01 PM
Breaking apart a Stacked Wall Issue
Wed, Mar 11, 2009 at 12:03:44 PM
Staggered Stacked Wall Join Problems
Tue, Oct 14, 2008 at 12:50:52 PM
Page generation time: 7.6452
