Forums >> Community >> Newbies >> Can not open the central or local file
Mon, Nov 23, 2009 at 9:50:13 AM | Can not open the central or local file
travo352
 I was working on a project and when I came back the next day I got this message:
"Can't edit the element until 'caduser1' resaves the element to central and relinquishes it and you Reload Latest."
I requested that the caduser resave and relinquish. When the caduser went to open the file he received the same message:
"Can't edit the element until 'caduser2' resaves the element to central and relinquishes it and you Reload Latest."
So I need caduser1 to resave and relinquish but he can't until caduser2 resaves and relinquishes but he can't until caduser1 does.
Has anyone run into this before?
Mon, Nov 23, 2009 at 10:18:47 AM | Can not open the central or local file
We all probably have.  You have users who have saved without relinquishing.  Change your user name under options to the offending party, open the central and save reliquishing all, then close and change your name back before opening your local.
Mon, Nov 23, 2009 at 7:49:02 PM | Can not open the central or local file
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
This will override all the work that person has done thought correct ww?
J. Allen Ball
Revit Architecture 2010 Certified Professional
Tue, Nov 24, 2009 at 5:58:04 AM | Can not open the central or local file
Allen, that is a possibility but often the problem is just someone poking around in the file.  If this user does have something valuable in his local, he can always open his file detached and copy paste from that to a new local.
Can not create local file from Central
Tue, Mar 6, 2012 at 11:57:26 AM
detach from central file
Wed, May 12, 2010 at 12:28:23 PM
How do i know its a Central File?
Tue, May 8, 2012 at 8:42:22 AM
Central/Local File Synchronizing Issue
Sun, Jun 23, 2013 at 2:33:20 PM
Central File Path on a local file
Sat, Oct 24, 2015 at 10:21:20 AM
Page generation time: 4.6744
