9 Users Online (7 Members):
Forums >> Revit Building >> Technical Support >> Grid Line - Annotation
9 Posts No Rating |
I am having trouble with my grid lines not showing on all of my plans. I have tried everything I know and still they show on some and not on other for no apparent reason. Does anyone have a suggestion or know what is going on
The gridlines have to extend through the rage of view to be seen. Read this topic in your HELP "Datum Extents and Visibility"
9 Posts No Rating |
That doesn't seem to be the problem. The views are cut at the same level and the grids are turned on. I even tried to see if it was an issue with the phasing, but nothing seems to work. I have a call into a Support company, I'll let you know if they know how to fix the problem . . .Thanks for your responce!
9 Posts No Rating |
WWhub- I am not sure if this will make sense but . . . when making the building sections look graphically correct by pulling the bottom end of the grid line up so that they didn't intersect the section I did not change the small '3D' to '2D' before I pulled it up. So . . . I guess I actually changed the extents of the grid line in three dimensions. Does that make sense? I figured it out before the support center called me back and it was hard to explain to them . . . . sorry, but thanks for your help!
Space between Grid Head and Grid Line not wanted! |
Mon, Jan 28, 2013 at 4:14:54 PM
Curved/Arc Grid Line - NOT DASHED |
Thu, Oct 13, 2011 at 11:22:19 PM
Column Grid Line Weight |
Sun, Aug 13, 2017 at 3:05:53 AM
Grid Dimensioning |
Tue, Jun 3, 2008 at 5:49:38 PM
Grid Partial Visibility |
Wed, Aug 3, 2016 at 1:08:39 PM
