I have a few questions of things I cant seem to figure out. i was hoping someone may know some or all of these. Please answer any you know of, any help is appreciated. 1. Is there a default setting for the throw of the section view when adding it to the plan? Sometimes, it seems to go way too long, even if I only make the length of it 10' or so. 2. Is there a setting for the distance of the columnline bubble from a crop view? Sometimes I want to move the bubbles closer to the crop view, but it seems to be a set distance. The model is linked in, and the crop view of the linked file shows the bubbles automatically. Is there a way to even turn it off so the bubbles dont show, but the column lines do? 3. Is it possible to eliminate the detail tag when placing a detail onto a sheet? Since I dont want them, I just move them below the border of the sheet, but is there a way to prevent them? 4. Is there a way to modify the text so the leader line is centered within the first line of text? I would think the leader line should be autocentered, but even on a single line of text the text is not centered. Can this be corrected? 5. Why in some views I cant change the cut plane? How is it set in those case, and how would I set it?
- Not that I know of. You should always adjust this anyway to minimize what revit has to deal with in the view.
- Check out you annotation crop limits.
- You can hide view tags hide individually.
- Can't adjust the leader origin.
- You should be able to change the cut plane in every view. Sections and elevations are where the view line is located, plans are set through VP.
