73 Users Online (72 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> how could I add a slope in my roof by extrusion? Revit2010
Mon, Sep 28, 2009 at 10:00:58 AM | how could I add a slope in my roof by extrusion? Revit2010
Nightsheep
Nightsheep Avatar
Hello,
 I created a roof by extrusion and I want to add a slope on this roof, (I would like to incline this roof) .
I use Revit 2010
Thank you.
Mon, Sep 28, 2009 at 10:05:39 AM | how could I add a slope in my roof by extrusion? Revit2010
3.5 Stars: 389 Votes
Edit the roof and change your sketch.....
Wed, Sep 30, 2009 at 10:17:41 AM | how could I add a slope in my roof by extrusion? Revit2010
Nightsheep
Nightsheep Avatar
if I edit the roof, I edit the roof profil because is a roof by extrusion. the option slope doesn't exist  in the "edit profile".
so How could I do to put a slope?
Thank you
Wed, Sep 30, 2009 at 10:21:05 AM | how could I add a slope in my roof by extrusion? Revit2010
See "Sketching a Roof by Extrusion" in your HELP..   The slope of the roof is determined by your sketch ...
Wed, Sep 30, 2009 at 11:53:40 AM | how could I add a slope in my roof by extrusion? Revit2010
Nightsheep
Nightsheep Avatar
My question wasn't very clear. In fact I don't want a slope on my roof but I want to incline, to lean  it.
my profil looks like  multiples semcircular line( corrugated iron). The result of the extrusion works very well, but I want to incline the roof.
For example, when I am in my elevation view , I can select my roof and if I could rotate it, it would be very nice but Revit said "Can't change plane of Roof Sketch."
Sorry I am french and it's difficult to explain it.
Thank you.
Wed, Sep 30, 2009 at 12:00:14 PM | how could I add a slope in my roof by extrusion? Revit2010
Use a different host plane for your sketch insteand of the floor or roof plan.  You will first have to create this sloping plane in an elevation view.  Name the plane then you may be able to select your roof and change its host or you may have to recreate your roof using this new work plane.  When you start a roof by extrusion, you can set the plane.
Fri, Oct 2, 2009 at 11:53:22 AM | how could I add a slope in my roof by extrusion? Revit2010
Nightsheep
Nightsheep Avatar
Hello,
I created a sloping plan in my elevation. I can't host my roof for the new plan. Even if I recreate my roof I can't set on my sloping plan , Revit accepts all the perpendicular plane for Extrusion but it ignores my sloping plane: When I want to create a Roof by Extrusion and I am in my sloping plan , a box "work plane" opens and in "specify a new work plane" the name of my sloping plan doesn't appear. If I am not in my sloping plan this box doesn't show  and I can start my roof by extrusion but is not inclined.
May be I should create a mass, but it sounds difficult.
 Thank you for you help.
Fri, Oct 2, 2009 at 12:53:09 PM | how could I add a slope in my roof by extrusion? Revit2010
4 Stars: 201 Votes
Put some images so we can see what really you try to do...
Sat, Oct 3, 2009 at 10:30:21 AM | how could I add a slope in my roof by extrusion? Revit2010
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
Please tell me that you are drawing the extrusion profile in a elevation view and not a plan view??? roof extrusion need to be drawn in elevation and that how you set the slop just like Typhoon said!!
*FACE PLANT*
J. Allen Ball
Revit Architecture 2010 Certified Professional
Mon, Oct 5, 2009 at 3:17:56 PM | how could I add a slope in my roof by extrusion? Revit2010
Nightsheep
Nightsheep Avatar
Yes I drew my extrusion roof on the elevation view
I put some images. I want to put a slope on my extrusion roof on the House 2 as the house1, but of course the roof of the house 2 is a extrusion roof.
Mon, Oct 5, 2009 at 3:43:12 PM | how could I add a slope in my roof by extrusion? Revit2010
#11
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
OK KNOW I SEE YOUR PROBLEM, GOTO A 3D VIEW AND CLICK ON THE ROOF, RIGHT NEXT TO THE ELEMENT TAB, THERE WILL BE A TAB CALLED "SHAPE EDITING" CLICK ADD POINT. THAT WILL GIVE YOU POINTS ON EACH CORNER OF THE ROOF. THERE YOU CAN SELECT THE POINTS AND CHANGE THERE LOCATION ON THE Z AXIS WHICH WILL GIVE YOU YOUR SLOPE.
J. Allen Ball
Wed, Oct 7, 2009 at 12:43:47 PM | how could I add a slope in my roof by extrusion? Revit2010
#12
Wolfmann16
can't u just cut a section through it and rotate it to the specified angle? That's what I usually do for a simple slope like that...
Tue, Oct 13, 2009 at 2:57:28 PM | how could I add a slope in my roof by extrusion? Revit2010
#13
Nightsheep
Nightsheep Avatar
@AllenBall: I didn't know this tool. It's nice but it doesn't work for my roof because I can't access to this "tool".
 Revit Architecture Help says " Shape Editing for Structural Floors, Roofs and Floors
In order to enable shape editing tools, the following conditions must be met:
  • Structural Floors must be flat and on a horizontal plane."
I think my roof isn't considerate as a flat roof because If I create a normal flat roof this tool works.
@Wolfmann: In my section view I can't rotate the roof it says"Error: Can't change plane of Roof Sketch."
Thank you for your help.
Edited on: Tue, Oct 13, 2009 at 2:59:46 PM
Tue, Oct 13, 2009 at 3:37:04 PM | how could I add a slope in my roof by extrusion? Revit2010
#14
mrmoo
mrmoo Avatar
2 Stars: 1 Votes
...working with wolfmann's suggestion; in order to rotate the roof, you need to dissassociate it from the work plane first.
Tue, Oct 13, 2009 at 3:37:48 PM | how could I add a slope in my roof by extrusion? Revit2010
#15
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
IF ALL ELSE FAILS YOU COULD DO A INPLACE MODEL AND MAKE IT A ROOF CATEGORY AND JUST DO A SWEEP. BUT I WOULD ONLY DO THAT AS A LAST RESORT.
J. Allen Ball
Joining Roof By Extrusion
Mon, Jan 31, 2011 at 8:15:14 AM
How do I slope a curved roof by extrusion??
Thu, Sep 15, 2016 at 6:52:06 AM
Barrel tile roof by extrusion
Fri, Jan 14, 2011 at 1:10:17 PM
Velux Window in Roof Slope
Thu, Jun 4, 2009 at 4:12:04 PM
Roof slope not showing up correct
Thu, Jul 11, 2013 at 10:37:30 AM
Page generation time: 0.6613
