Forums >> Revit Building >> Technical Support >> Different textures on the one floor
Sat, Aug 13, 2005 at 3:58:57 AM | Different textures on the one floor
alangero
Does anybody know how to change the render material on the floor within the same room. I am trying to place down a synthetic floor covering and carpet in the one room (meal / lounge) Is there a way of doing it without changing the floor properties?
Sat, Aug 13, 2005 at 5:49:29 AM | RE: Different textures on the one floor
eepa
5 Stars: 2 Votes
Did you try with 'Split face'?
Sun, Aug 14, 2005 at 11:21:38 AM | RE: Different textures on the one floor
TomDorner
4.5 Stars: 25 Votes
I would model the floor just like it occurs in the real world. You have a "structural" floor system and then on top of that different finish floor systems. Just make the floors on top of each other and all should work out not only rendering wise but schedule wise as well. Just remember the Revit mantra "model it like you build it". HTH Tom
free hi res textures
Mon, Apr 13, 2009 at 2:47:29 AM
Revit render textures - any good resources on the web?
Thu, Dec 16, 2010 at 10:54:15 AM
adding textures to wall
Tue, Oct 17, 2006 at 9:27:46 PM
High Res Textures for Rendering
Fri, Apr 17, 2009 at 12:15:29 PM
ADD TEXTURES AND HATCHS
Wed, May 6, 2009 at 7:59:50 AM
Page generation time: 1.3539
