373 Users Online (24 Members):
- Most ever was 3914 - Wed, Aug 26, 2026 at 4:53:14 AM |
Forums >> Revit Building >> Technical Support >> Hotfix - Crash when deleting or modifying walls
To all of you, directly from Autodesk:http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13778933&linkID=9273944&CMP=OTC-RSSSUP01 Published date: 2009-Aug-21 ID: DL13778933 Applies to: Autodesk®Revit Architecture 2010 Autodesk®Revit MEP 2010 Autodesk® Revit Structure 2010 This hotfix addresses issues related to deleting or modifying walls, a crash may occur. Make sure to download the correct patch for your operating system (32 or 64 bit). The Readme contains the latest information regarding the installation and use of this update. It is strongly recommended that you read the entire document before you apply the update to your product. For your reference, you should save the Readme to your hard drive or print a copy.
Edited on: Sat, Aug 22, 2009 at 8:22:27 AM
Hotfix - Autodesk Revit 2013 - Server and Part Family |
Fri, Feb 1, 2013 at 3:30:47 AM
Revit Fatal Error |
Sat, Jan 9, 2010 at 7:30:35 PM
REVIT 2013 problems after Installing 2014 |
Sun, Jun 2, 2013 at 10:50:31 PM
Modify bar not updating |
Thu, May 23, 2013 at 3:46:08 PM
Deleting Problems (Revit 2009) |
Mon, Oct 27, 2008 at 9:21:15 AM
Members: | 2188039 | Objects: | 23399 | Forum Posts: | 152455 | Job Listings: | 0 |
