600 Users Online (25 Members): Show Users Online - Most ever was 3914 - Wed, Aug 26, 2026 at 4:53:14 AM
Forums >> Revit Building >> Technical Support >> HELP! Keynote problems
Thu, Aug 6, 2009 at 1:54:50 PM | HELP! Keynote problems
MARS1276
1 Stars: 1 Votes
I am finding that when I go back to a section or elevation view, that some of my keynote leaders have literally moved away from their assigned host.  Thereby giving the '?'.  I then have to move the leader BACK in place again.  Has anyone else experienced this problem?  It's really annoying and Pinning the keynote itself doesn't seem to help.
Any ideas?
Mars
Thu, Aug 6, 2009 at 8:50:03 PM | HELP! Keynote problems
TomDorner
4.5 Stars: 25 Votes
Have the leaders moved away from the object, or did the object move away from the leader?
I suspect that the latter is the case and is causing the missed leader.
Tom
Tue, Aug 11, 2009 at 9:00:59 AM | HELP! Keynote problems
MARS1276
1 Stars: 1 Votes
In this case, the leaders are moving away from the object.  I have opened the same project multiple times and have had the same problem in the elevation views as well as the wall section views.  Nothing has moved.  One day they will be in place and the next day the project file may show them moved, displaying the ? mark.
Any ideas on this one?  I tried pinning the text but that doesn't seem to help.
Tue, Aug 11, 2009 at 9:23:25 AM | HELP! Keynote problems
When you placed the keynote, did you pay attention to what you were pointing to and tab through that to get the correct item?
Did you copy the keynote around rather than placing it?
Tue, Aug 11, 2009 at 2:29:33 PM | HELP! Keynote problems
MARS1276
1 Stars: 1 Votes
Thanks for your reply.  The situation I have is: I am keynoting an 8" (metal panel) girt wall.  Now I have added profiles to this wall to create the z-girts, C-Base Channel, and the drip edge at the bottom.  I have established a material type for each profile with it's own keynote as part of the material identity.  The issue here is, sometimes when I go back to my elevation or section views, the keynote that was pointing to the "material" element (profile) is now a question mark.
 I did not copy the keynote as I have already found that does not work well (if at all).
 So it's a little sketchy as to why Revit behaves this way.  I would like to figure a way to prevent this from happening.
Tue, Aug 11, 2009 at 2:36:06 PM | HELP! Keynote problems
MARS1276
1 Stars: 1 Votes
Tue, Aug 11, 2009 at 2:42:49 PM | HELP! Keynote problems
MARS1276
1 Stars: 1 Votes
Tue, Aug 11, 2009 at 2:57:17 PM | HELP! Keynote problems
A couple of possibilities.
  1. Section/elevation markers moved ... view still looks the  same.
  2. I've seen similar lost connections when something gets reloaded - like a family.
Tue, Aug 11, 2009 at 3:34:57 PM | HELP! Keynote problems
MARS1276
1 Stars: 1 Votes
You have a good point with your first possibility.  Like all other things, I'm going to see if section view markers can be pinned or locked.
Hopefully that is it.
Multiple Sets of Keyed Notes
Tue, Dec 14, 2010 at 7:11:26 AM
Keynote Legend Not Showing Keynote Text
Fri, Sep 6, 2013 at 11:40:59 AM
12
Keynote Text in Schedules
Thu, Sep 11, 2014 at 4:45:04 PM
Levels and Keyed Note
Fri, Jul 6, 2007 at 2:21:49 PM
Project Keynotes
Wed, Oct 21, 2009 at 4:07:24 PM
Page generation time: 0.3547
