Forums >> Community >> Newbies >> Revit model from 3D MAx model
Wed, Aug 5, 2009 at 11:01:13 AM | Revit model from 3D MAx model
Al7amdlellah
Hi,
I have this model in 3D studio formate and sketch up format. I tried to import it to Revit and creat a model out of it but no sucess. Can anyone help and guide me
File attached is DWG and Sketch up
Thanks
Wed, Aug 5, 2009 at 12:53:48 PM | Revit model from 3D MAx model
4 Stars: 205 Votes
Go to Massing and create a new mass, then give it the name and go to file>import link>CAD formats, you can choose if you want the sketchup model or the DWG file, then finish the mass and now you can apply Walls, Floors, roofs and Curtain system BY FACE.
Wed, Aug 5, 2009 at 1:40:10 PM | Revit model from 3D MAx model
Al7amdlellah
I got a warning saying "Mass Contains only mesh Geometry, whcih can not be used to compute mass floors, volume, or surface area". Is that ok?
Thanks
Wed, Aug 5, 2009 at 1:53:30 PM | Revit model from 3D MAx model
Al7amdlellah
When I cut through the imported mass, I get void inside. Is there a way to get a solid filled object from the imported 3D model. Do I need to do anything in sketchup, autocad or 3DS before exporting to Revit
Thanks
Wed, Aug 5, 2009 at 2:07:16 PM | Revit model from 3D MAx model
4 Stars: 205 Votes
Yeah, check the units before you export the model and when you import the model in Revit, because i think you have the model very big, that's why when you apply the walls by face and when you "Cut" the model appears that "void" you talking....
Revit 10 Model to FBX to 3Ds Studio Max Design lighting problem
Sat, May 1, 2010 at 12:55:25 PM
Exporting Revit 9.1 Model to 3ds Max, Material Issues
Tue, Oct 16, 2007 at 10:38:26 AM
Revit to 3d Max FBX [ 1 2 ]
Wed, Dec 1, 2010 at 8:52:13 PM
17
Revit FBX to 3D Max 2011 causes black or unresponsive viewports
Fri, Jan 13, 2012 at 11:29:51 AM
Revit FBX causes 3DS Max to crash
Wed, Aug 10, 2016 at 6:02:27 PM
Page generation time: 2.7283
