Forums >> Revit Building >> Technical Support >> Select an Object and watch it move!!!
Tue, Aug 4, 2009 at 5:46:50 PM | Select an Object and watch it move!!!
JMBknvc
JMBknvc Avatar
We have been having a problem in the office with some of our Revit Architecture 2010 Computers.  When you select an object, the object you selected automatically moves a short distance straight up.  Once this starts to happen anything you select automatically moves.  So, working in Revit becomes impossible.  When the problem starts you can go to any Revite file and have the same problem happen.  Meanwhile, someone without the automactic moving problem can open the file and work without any problems.  To make the problem go away we have done a system restore and then loaded the Revite Patch.  That has seemed to work for a couple of the computers but we are still having the Automatic Moving Problem on one computer.  If anyone has ran across this problem I would like to know.  Really wanting to know what is causing the problem and what is the fix to make the problem go away.
Tue, Aug 4, 2009 at 6:03:21 PM | Select an Object and watch it move!!!
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
Sounds like you may be having issues with your options bar doubling in size thus causing your selection to mudge up to compensate for the lost space. A lot of times this is solved by using Autocad Certified drivers for your graphics card. My guess is you are using some verion of the Nvidia Quadro. I would also check your Nvidia control panel and try different configurations of your "multiple display" setup if using dual monitors
Dimensions will not highlight when i select an object
Thu, Jan 5, 2012 at 3:02:15 PM
What is the purpose of the dashed blue window when using the move command?
Thu, Apr 2, 2015 at 1:18:06 PM
dimensions
Mon, Jun 2, 2008 at 3:21:30 PM
objects move in Y-axis but not X-axis
Wed, Nov 2, 2005 at 11:04:31 PM
cant select object even when I tab.
Tue, May 8, 2012 at 4:38:37 PM
Page generation time: 1.4421
