Forums >> Revit Systems >> Technical Support >> Warnings when creating spaces
Wed, Jul 22, 2009 at 1:12:50 PM | Warnings when creating spaces
koolair
4.5 Stars: 2 Votes
Hello again!
I get the following two warnings when creating spaces:
1)  None of the created elements are visible in Floor Plan: 1 - Plumbing View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings.
2) Could not create geometry for Space.
I am MEP 2009, working on a workset I created called "Shared Spaces and Zones", my upper limit is set at Level 2 with Offset 0.0.  Tag on placement is checked off.
Hope someone's got some ideas...
Thanks
Wed, Jul 22, 2009 at 1:39:24 PM | Warnings when creating spaces
Are rooms on?
 Do you own the walls or is it a linked file?
20010?
Wed, Jul 22, 2009 at 2:12:54 PM | Warnings when creating spaces
koolair
4.5 Stars: 2 Votes
Hub, I've got four arch linked files and one structural linked file.  I'm on 2009.
I don't know if I turned on/off the rooms.  Room bounding is checked.
Revit Spaces Elec VS Mech
Tue, Feb 2, 2010 at 10:50:50 AM
Clear out warnings to increase file speed.
Tue, Nov 27, 2007 at 4:14:46 PM
dimension text format, remove extra spaces
Tue, Aug 24, 2004 at 8:38:42 PM
Multiple Parking spaces - line based family, need help
Tue, Jul 29, 2014 at 4:34:35 PM
11
Warnings: Duplicate Door Not Found
Wed, Jul 6, 2011 at 2:33:08 PM
Page generation time: 0.1714
