Forums >> Revit Building >> Technical Support >> custom color setting do not display
Tue, Jul 21, 2009 at 8:24:34 PM | custom color setting do not display
tomribbons
I am using the 64 bit version of 2010 revit, but the 32 bit  version displayed the same problem.  I have created an element which is a floor.   Under element properties > edit type > structure:edit > material : edit > shading I have unchecked"Use Render Apperance for Shading", have clicked on the color button and set the RGB settings to 196-251-253, Surface Pattern is set to None and Cut Pattern is set to None.  When looking at the floor in 3D Top view or any view I see the floor displayed with a light blue color.
However on the same floor when I change the RGB setting to 253-251-196 the color shows correct in the settings box, but in 3D top view or any view the floor shows up without any color!
Is there a reason the program is behaving this way, is there a limited set of colors it can display or is this a bug?
Any help willl be appreciated.
Thanks.
Tom
Revit Display Color changed
Thu, Feb 28, 2013 at 9:21:30 AM
Display worksets by color
Tue, Jun 17, 2008 at 11:54:46 PM
Turn of Color Fills
Fri, May 19, 2006 at 2:31:06 AM
Custom Window and Door Family display issues [ 1 2 ]
Fri, Aug 9, 2013 at 11:35:41 AM
15
Lighting Color
Sat, Apr 16, 2011 at 9:43:08 PM
Page generation time: 0.3424
