Forums >> Revit Building >> Technical Support >> not everything will mirror correctly in linked revit files
Thu, Jul 2, 2009 at 5:04:53 AM | not everything will mirror correctly in linked revit files
cgigiw
Hi,
I have linked a file into a new file (linked revit files), everything goes very well except when I mirror the linked file the room tag won't mirror correctly. The place doens't match with the room. Does anyone knows a solution for this problem?
Thanks!!
Thu, Jul 2, 2009 at 7:09:46 AM | not everything will mirror correctly in linked revit files
Nope ... REVIT doesn't always play well with mirrored items.  Maybe this is better in 2010.
Thu, Jul 2, 2009 at 9:28:25 AM | not everything will mirror correctly in linked revit files
rkitect
rkitect Avatar
4 Stars: 29 Votes
The solution is to retag the rooms.  Won't take long at all using the "Tag all not Tagged" tool.
autocad linked files and refresh
Tue, Apr 7, 2009 at 2:12:36 PM
View Properties of Linked Revit Files
Mon, Feb 15, 2010 at 9:56:22 PM
Can't filter "Phase Created" in MTO for linked Revit files?
Mon, May 12, 2014 at 7:01:45 AM
Linked Files Revit 2009
Wed, Aug 31, 2011 at 3:27:11 PM
export dwg including a linked revit file
Tue, Jul 31, 2012 at 12:30:21 PM
Page generation time: 1.7845
