11 Users Online (9 Members):
Forums >> Revit Structure >> Technical Support >> Beam to Column
19 Posts No Rating |
Hello I have a beam that I can stretch and everything with no problems. The thing is now I want a column with the same properties. Can I on some way just make the beam to a column?
To create a column use the family "Metric/Imperial Column" then attach the column to a ref. planes... if you attach to the levels the column "Move" if you move the height of the levels....
Thanks but can I in some way get arrows so I can streach them like that? arrow
If the beam are attached to the ref. planes you gonna see the arrows in project, then you can stretch by the arrows...
How to extend top flange of beam (over top of column)? |
Fri, Jun 15, 2012 at 10:35:08 AM
How to show beam column connection in plan properly |
Fri, Nov 7, 2014 at 12:53:30 PM
Tee beam as column? |
Tue, Nov 6, 2012 at 2:41:46 PM
beams not snapping to beam/column |
Fri, Feb 19, 2010 at 4:30:22 PM
Column Family/Beam Family |
Fri, Aug 27, 2010 at 1:25:52 PM
