Forums >> Revit Building >> Technical Support >> Filled Region Not Moving
Wed, Jun 10, 2009 at 9:02:27 AM | Filled Region Not Moving
emmettking
I am using Revit Architecture 2009:
 I have a ceiling plan view where i show the plumbing penetrations from above.  The plumbing penetrations are shown with a filled region.  The toilets have shifted and now i need to move the filled regions.  When i went back to the plan i was unable to move the filled regions.  i cannot tab and select them either it will not let me select the regions.  I am stumped and any suggestions would be greatly appreciated.
Thanks,
Wed, Jun 10, 2009 at 9:18:11 AM | Filled Region Not Moving
emmettking
I have an answer to my own problem.
 The filled regions visibility is controled through detail items.  However the filled regions boundary visibility is controlled through Lines.  It seems someone had turned off the visibility of thin lines, which was what the filled region's boundary was created with, thus not allowing the filled region to be editable, nad not allwoing me to move the regions or change their sizes.  Hope this helps out people in the future.
Remove Model Filled Region @ Fixtures
Wed, Aug 15, 2012 at 4:19:33 PM
Deleting Types From Filled Region Families
Tue, Sep 9, 2008 at 6:56:41 PM
filled region pattern color changes when drawing scale changes
Thu, Apr 14, 2016 at 7:32:06 AM
FILLED REGION IN 3D VIEW OR PERSPECTIVE VIEW
Wed, Jan 26, 2011 at 5:10:05 PM
Visibility of Filled Region Boundaries over walls
Wed, May 24, 2017 at 1:54:59 PM
Page generation time: 0.1109
