36 Users Online (35 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Question for Revit Masters - Basics of Flex and Constraints - Diagonal Lines
Fri, Jun 5, 2009 at 1:28:29 PM | Question for Revit Masters - Basics of Flex and Constraints - Diagonal Lines
hank
3.5 Stars: 3 Votes
OK, Check this scenario out that has been driving me crazy...
Here is a basic bunch of 2D lines locked to some reference planes:
See how everything flexes nicely when I drag the Right reference plane:
Now I'll add some diagonal lines and lock them to the outer reference planes as well:
See how I the constraints cannot be maintained for the diagonal lines:
My question is... WHY!!!?
Edited on: Fri, Jun 5, 2009 at 8:33:50 AM
Fri, Jun 5, 2009 at 3:57:05 PM | Question for Revit Masters - Basics of Flex and Constraints - Diagonal Lines
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
Hank,
I have done this before, I drew 1 single diagnol line to the intersection and constrained it. once I verify that single line would flex i then mirror it around and voila, it worked.
see attached
Sun, Jun 7, 2009 at 4:25:09 PM | Question for Revit Masters - Basics of Flex and Constraints - Diagonal Lines
hank
3.5 Stars: 3 Votes
Thanks alabaster.  i guess my question now is why?  I've been using these kinds of workarounds with Revit more and more and I think it indicates my lack of understanding what Revit is looking for and/or a poor explanation of the logic by AutoDesk itself.  Most people probably don't care why but it bothers me that a program this sophisticated has to be handled with guesses and hacks.
So does anyone know if this happens because the existence of the constrained rectangle somehow prevents newer constraints.  Are constraints prioritized by the order in which objects are created?
Thanks in advance - this seems like it may be unanswerable without getting a Revit programmer on here.
Mon, Jun 8, 2009 at 12:54:27 PM | Question for Revit Masters - Basics of Flex and Constraints - Diagonal Lines
coreed
coreed Avatar
4 Stars: 16 Votes
if you add the diagonal lines and lock them, then you are telling Revit to keep them at that angle. So Revit is correct in telling you that "constrains are not satisfied". because it would be impossible to keep the lines at that angle without changing the witdth and height as you flex the the shape.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tue, Jun 9, 2009 at 6:33:53 PM | Question for Revit Masters - Basics of Flex and Constraints - Diagonal Lines
hank
3.5 Stars: 3 Votes
Hey coreed.  yeah, but it DOES work sometimes as alabaster mentioned.
Tue, Jun 9, 2009 at 8:43:48 PM | Question for Revit Masters - Basics of Flex and Constraints - Diagonal Lines
chanus
Here you do not want to lock to the plane of the line. In this instance you want to lock to the end point of the line. When ready to lock the diagonal line to the plane (at a mid point plane also) click on the plane and then tab over the model line and find the point, when you have that point highlighted click on it.
Cheers,
Tue, Jun 9, 2009 at 9:25:13 PM | Question for Revit Masters - Basics of Flex and Constraints - Diagonal Lines
3.5 Stars: 385 Votes
hank - I like your challenge - this is a tough one, I've not run across this .... working on it.  Maybe Mr Spot will have an answer
alabaster & chanus ... you should try your answer out.... doesn't work for me
Wed, Jun 10, 2009 at 12:18:13 PM | Question for Revit Masters - Basics of Flex and Constraints - Diagonal Lines
chanus
It works, I pinky promise. Send me the file and I will prove it.... Smile
Wed, Jun 10, 2009 at 12:35:09 PM | Question for Revit Masters - Basics of Flex and Constraints - Diagonal Lines
rkitect
rkitect Avatar
4 Stars: 29 Votes
My first suggestion would be to look at the out of the box door families.  In elevation, many of them have swing lines that are diagonal lines that flex with the door width/height.  Take a look at those and see if you can decipher them.  I think you'll find the key is not constraining (actually locking the lines) but letting Revit use it's "smart" constraints for the diagonal lines.
Good luck!
Wed, Jun 10, 2009 at 12:47:02 PM | Question for Revit Masters - Basics of Flex and Constraints - Diagonal Lines
rkitect
rkitect Avatar
4 Stars: 29 Votes
Also, instead of "Dragging" the right ref plane, try making it parametric.  Meaning link a dimension parameter to it (make it instance instead of type if you wan tto drag it in the project) and change the dimension via family types dialogue instead of dragging it.  See if that works better.
Wed, Jun 10, 2009 at 12:52:57 PM | Question for Revit Masters - Basics of Flex and Constraints - Diagonal Lines
#11
rkitect
rkitect Avatar
4 Stars: 29 Votes
See if this video explains what you are asking: http://gibsonhh.info/revit/video/lineConstraints.swf
Wed, Jun 10, 2009 at 1:11:39 PM | Question for Revit Masters - Basics of Flex and Constraints - Diagonal Lines
#12
chanus
Hank,
 Please see the attached file, Flexing the parameters in the types window works.
Cheers,
Wed, Jun 10, 2009 at 1:20:19 PM | Question for Revit Masters - Basics of Flex and Constraints - Diagonal Lines
#13
thanks rkitect ... I was being stupid and trying to lock ... This is proof that locks can get you into trouble.  REVIT assumes some associations on its own and you don't have to lock everything ... and in this case, if you notice, Carl doesn't use any locks at all.
Wed, Jun 10, 2009 at 3:08:46 PM | Question for Revit Masters - Basics of Flex and Constraints - Diagonal Lines
#14
coreed
coreed Avatar
4 Stars: 16 Votes
but rkitect is doing exactly what i said, he's changing the witdth and the height so that they are equal.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, Jun 10, 2009 at 5:08:06 PM | Question for Revit Masters - Basics of Flex and Constraints - Diagonal Lines
#15
alabaster2513
3.5 Stars: 25 Votes
Hank,
I think your main problem is your associating the four lines of your diamond to each other and this is preventing the flexability your are trying to achieve. By first creating a single diagonal line that flexes both vertically and horizontally then mirroring this element you are creating 4 completely independant lines that are able to flex vertically and horizontally. That is how you are able to prevent all four lines from maintaining their original shape.
Sink Family - Symbol Lines won't flex with Wall Change in Section View
Mon, Mar 9, 2009 at 10:26:15 PM
Model Line constraints in family editor
Mon, Aug 15, 2011 at 4:46:25 PM
Curtain wall mullion - corner lines diagonal?
Wed, Dec 9, 2015 at 1:31:31 PM
flex duct tag
Thu, Jun 11, 2009 at 2:27:25 PM
Window family won't flex
Fri, Jan 14, 2005 at 1:42:12 AM
Page generation time: 1.9910
