Forums >> Community >> The Studio >> BRICK VENEER WALL
Thu, Jul 21, 2005 at 9:59:07 PM | BRICK VENEER WALL
dj001
4.5 Stars: 4 Votes
I NEED TO CREAT A BRICK VENEER WALL WITH THE BRICK ONLY TO BE 1200 HIGH WITH THE REST AL THE WALL FULL HEIGHT. CAN YOU HELP??
Thu, Jul 21, 2005 at 10:07:09 PM | RE: BRICK VENEER WALL
meelio
2 Stars: 3 Votes
I replied to this in your wishlist post - check it out.
Fri, Jul 22, 2005 at 8:55:04 AM | RE: BRICK VENEER WALL
arnosandoval
5 Stars: 3 Votes
I would recommend using a stacked wall system, where you take two wall types and stack them. YOu can define one to be at that 1200 height. Another way is to modify the materials you have for that wall. If you click on edit, structure,click on preview and preview in section you get some bottons become available to you. Click on the one for split region and select the brick, then just move that split line to the height you want. THen assign a layer to the remainder face of that wall to be what you want it to be. The Revit tutorials offer good examples on how to modify walls. HTH.
230 brick wall wont cleanup to 250 brick veneer wall (images attached) RA2008
Wed, Sep 3, 2008 at 12:33:09 AM
Stone Wall
Tue, Aug 20, 2013 at 3:55:33 PM
Brick veneer stepping at alternate elevations
Wed, Aug 14, 2013 at 8:28:36 PM
brick veneer window insertion question
Tue, Nov 23, 2004 at 4:28:49 PM
Window Placement in Stud/Brick Veneer Wall [ 1 2 ]
Wed, Feb 4, 2009 at 11:22:19 AM
15
Page generation time: 0.7459
