Forums >> Revit Systems >> Technical Support >> R2010, Vista 64 bit...Crashes!!!
Tue, May 26, 2009 at 9:46:21 AM | R2010, Vista 64 bit...Crashes!!!
Struxturearc
So this morning we had a nice little treat.  Any project we have done crashes and has a fatal error when we try to open it.  After working on it for hours, we think it is a Vista problem. There was an update over the weekend, and ANY project (in 2009 or 2010) we try to open crashes and has to close.  However we can open anything (including 2010) on a XP machine.  We were all working on it just last friday as well with 0 issues.  We have tried everything.  Detaching, auditing, even reinstalling Revit 2010.
Has anyone else had this issue today (maybe since the Microsoft update this weekend?)
 thanks
Tue, May 26, 2009 at 10:03:15 AM | R2010, Vista 64 bit...Crashes!!!
qabulin
qabulin Avatar
Can you please go to the Windows Update dialog window, click on View History, and then provide the update name(s), KB code, Definition number and date installed?  Please do this with either whatever you THINK was installed last or at least the last five update.
<qab>
qab
^_^
Debian + VirtualBox + Revit
Tue, May 26, 2009 at 10:04:54 AM | R2010, Vista 64 bit...Crashes!!!
coreed
coreed Avatar
4 Stars: 16 Votes
see if your update installed IE8 -Internet Explore 8-
if so, that may be the problem
Edited on: Tue, May 26, 2009 at 10:05:42 AM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tue, May 26, 2009 at 10:09:41 AM | R2010, Vista 64 bit...Crashes!!!
qabulin
qabulin Avatar
.... as I would imagine that you would be in a hurry to get some work done, use the Snipping Tool in your Accessories folder to save an image of the "View update history" window maximized (or simply get a screenshot), and then try a system restore to a time it was working.
 You can use the snipping image to later review and debug the issue.
IMPORTANT:
Backup your data before doing a system restore.
qab
^_^
Tue, May 26, 2009 at 11:13:32 AM | R2010, Vista 64 bit...Crashes!!!
Struxturearc
ok guys, thanks for your responses.  After a few of us (IT guy included) were messing with this for the last 2.5 hrs, ALL that needed done was our machines needed to be shut down and restarded. This fixed everything.  We are so mad we didnt try that first. Oh well.  The good news is nothing from Friday was lost and we can keep working!
Tue, May 26, 2009 at 11:55:55 AM | R2010, Vista 64 bit...Crashes!!!
qabulin
qabulin Avatar
That's great! ^_^
Congrats on the easy fix!
qab
^_^
HP DESIGN JET 1050C FOR VISTA 64 BIT
Fri, Apr 18, 2008 at 6:39:35 PM
64 bit revit, 64 bit vista and multi-cores... [ 1 2 ]
Sat, Apr 4, 2009 at 1:38:57 AM
29
2010 and vista 32-bit
Thu, May 7, 2009 at 10:40:48 PM
11
Vista 64-bit Memory Query
Wed, Nov 17, 2010 at 2:01:25 PM
64 bit screensaver crash
Fri, Dec 18, 2009 at 9:17:00 AM
Page generation time: 2.1153
