Forums >> Revit Building >> Technical Support >> Type Cataloge by Familiy Type
Fri, May 22, 2009 at 12:20:35 PM | Type Cataloge by Familiy Type
baumax
Hi,
i wanted to make a cataloge by familiy types.  The Situation is: I have a familiy with lots of Types already buildt in the Familiy itself. Now i want to have a Cataloge, from which i can select the Type i need and load into my current project.
Example: My Families Name ist "Test". Types are "Square" and "Round".  I made my cataloge like:
,typename##other##
Square, Test : Square
Round, Test : Round
When i load the Family i get the cataloge and can see and select the Types. When the Familiy loads into the Project, i get an error-Message which says "Parameter typename is not valid" (German version).  The Help-File says: enter column-name##other##. The column name is the same as the Family Type parameter name. Obviously i didnt set up the Family Type Parameter name correctly. Has anyone a solution for that problem?
 Thx and regards
  Max
Edited on: Fri, May 22, 2009 at 12:26:08 PM
Edited on: Fri, May 22, 2009 at 12:26:56 PM
Linking a Pype type to a certain System type
Thu, Aug 14, 2014 at 12:33:58 PM
excluding a type in the family type parameter
Thu, Mar 20, 2008 at 3:38:32 AM
Wall Thickness in Type Parameter
Fri, Jun 1, 2018 at 7:39:15 AM
Same Door Type, Different Frame Type
Thu, Jul 24, 2008 at 3:16:26 PM
Delete Section Type
Wed, Dec 14, 2011 at 7:04:23 AM
Page generation time: 0.2711
