Forums >> Workflow & Implementation >> Worksets >> Getting rid of Worksets
Fri, Feb 20, 2004 at 7:53:17 AM | Getting rid of Worksets
Team RPM
Is it possible to get rid of the worksets from a job after worksets have been enabled?
Fri, Feb 20, 2004 at 3:18:14 PM | RE: Getting rid of Worksets
Steve_Stafford
5 Stars: 2 Votes
No...like the warning message said...no going back. But if you are the only person using them, just check all of them out at the beginning of the day...and you CAN put everything back into one workset, at least objects you can. Worksets can bring some definite advantages to even a single person job. Post edited on 2004-02-20 15:20:26
Mon, Jul 25, 2005 at 11:20:29 AM | RE: Getting rid of Worksets
SHDesign
1 Stars: 1 Votes
I came on to Revit City with the same question...we had some drawings with worksets enabled, and they are getting to be prolemmatic. I don't know if there is another way (if there is, I'd love to hear it), but what I ended up doing was setting the view range, visibility, etc for my "Site" level so that everything in the entire model showed up and was editable. Then I created a new, blank project in the same Revit session, returned to the original drawing (the one with worksets enabled) and selected everything, and copied it to my clipboard. Then I went to the new project and Paste Aligned it into the new project... The new project contains all of the model information (except for the levels which were easily defined), but does not have any worksets to deal with.
revit worksets and centralized files
Wed, Dec 19, 2007 at 8:32:19 AM
Cant Delete one of My worksets...please help
Thu, Feb 14, 2019 at 1:48:12 PM
13
cannot enable worksets
Tue, Jan 23, 2018 at 11:00:18 AM
13
How do you get rid of old revision clouds?
Wed, Aug 15, 2012 at 12:15:08 PM
WORKSET - problem moving elements to the appropriate worksets PLEASE HELP
Wed, Feb 1, 2012 at 5:04:15 PM
Page generation time: 1.1974
