704 Users Online (39 Members): Show Users Online - Most ever was 3914 - Wed, Aug 26, 2026 at 4:53:14 AM
Forums >> Revit Building >> Technical Support >> Revit 2010 Stability
Search this ThreadSearch this Thread | Page 1 of 5 | 1 | 2 | 3 | 4 | 5 Next >>
Mon, May 18, 2009 at 3:58:48 PM | Revit 2010 Stability
BRIANHADLEY
Three or four times a day Revit 2010 will close with no warning, no option to save.  I never had this problem in 2009.  Anyone know whats going on?
Mon, May 18, 2009 at 4:43:10 PM | Revit 2010 Stability
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
go to
C:\Program Files\Autodesk Revit Architecture 2010\Journals
 and post attach your journal file from your latest crash so I can take a look.
Tue, May 19, 2009 at 5:22:46 AM | Revit 2010 Stability
robinballew
robinballew Avatar
3 Stars: 4 Votes
I have had similar issues. At least 4 or 5 times a day. Sometimes I get the save option sometimes I get nothing. It seems to be connected to Rooms but I can't be sure. I also turned off the direct x and that seems to help some. Looking forward to the first patch...
BallewDesigns.com
Tue, May 19, 2009 at 6:59:05 AM | Revit 2010 Stability
coreed
coreed Avatar
4 Stars: 16 Votes
are you guys running Internet Evplore 8?
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tue, May 19, 2009 at 8:24:47 AM | Revit 2010 Stability
BRIANHADLEY
I'm using explorer 7.  How do I know which journal file was from my latest crash?  Should I wait till my next crash and then use the last jounal file.
Tue, May 19, 2009 at 8:49:29 AM | Revit 2010 Stability
robinballew
robinballew Avatar
3 Stars: 4 Votes
IE 7 and Google Chrome and FireFox
BallewDesigns.com
Tue, May 19, 2009 at 9:26:59 AM | Revit 2010 Stability
coreed
coreed Avatar
4 Stars: 16 Votes
you can rule out IE8 then.
Edited on: Tue, May 19, 2009 at 9:27:16 AM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tue, May 19, 2009 at 10:47:01 AM | Revit 2010 Stability
BRIANHADLEY
Lets try again
Tue, May 19, 2009 at 12:03:12 PM | Revit 2010 Stability
alabaster2513
3.5 Stars: 25 Votes
I know very little about programming but researching the code given by your event
"0:< ExceptionCode=0xe0434f4d ExceptionFlags=0x00000001 ExceptionAddress=7C812AFB"
it seems Revit 2010 may have a memory leak on your machine... what that means I do not know. What are your system specs including your graphics driver version?
Wed, May 20, 2009 at 1:26:54 AM | Revit 2010 Stability
MCaputo
I'm having the same problem. I have just downloaded the worksharing monitoring extension from Autodesk subscription (if you have access to it) and had the system performance tool running in the background as i was working away...
It seems to crash everytime Revit's virtual memory runs out??
Check out "Verifying Virtual Memory Allocation" through revit help and it tells you where you can increase your VM. I haven't tried this just yet (i'll wait for my IT guy to do it) as im no PC expert and from what i've heard, this can cause some problems with windows and other programs on your PC.
i'll let you know if i have any luck.
HTH Smile
Wed, May 20, 2009 at 10:44:19 AM | Revit 2010 Stability
#11
alabaster2513
3.5 Stars: 25 Votes
increasing VM is simple, although I am not sure if 32bit has a ceiling, I know on vista 64bit I have like 20 gb of VM and dont have any issues.
Wed, Jun 3, 2009 at 2:38:00 PM | Revit 2010 Stability
#12
Mitsunobu
Mitsunobu Avatar
3 Stars: 2 Votes
It's a problem with the build itself. Autodesk released 2010 too early.  I have been getting unexplained and unduplicatable errors ever since I first started testing it, now that our entire team is moved onto 2010 we are just now getting even stranger behavior than we have ever seen before.  Funny thing is so far in my testing, Windows 7RC seems to have the least amount of trouble with revit. Boo to Autodesk.
Wed, Jun 3, 2009 at 2:47:05 PM | Revit 2010 Stability
#13
alabaster2513
3.5 Stars: 25 Votes
if its a problem with the build how am I able to run it on many different types of computers with a variety of operating systems, users, projects, hardware, drivers, blah blah blah?
My guess is your machines are not properly maintained or are not up to par with Revits requirements.
Wed, Jun 3, 2009 at 2:48:54 PM | Revit 2010 Stability
#14
4 Stars: 205 Votes
Mitsunobu, Put here the specs of your machine....
Wed, Jun 3, 2009 at 3:00:30 PM | Revit 2010 Stability
#15
Mitsunobu
Mitsunobu Avatar
3 Stars: 2 Votes
its not a single machine or deployment, like I said I have been testing it, on 32bit and 64 bit, on ATI and Nvidia, on WinServer2003 and Ubuntu server config. on xp sp2&sp3, vista, and win7, mutilple different chipsets and finally of course single standalone deployment. ooh look someone can give me some bad advice b/c they think they know the hardware better. thanks but you cannot help.
Web Update for Revit
Sat, Oct 3, 2009 at 5:30:17 AM
Something wrong with visibility
Fri, Oct 17, 2008 at 8:18:16 AM
Revit TotD – 2.22.10 | Save the trees, use DWF Markups!
Mon, Feb 22, 2010 at 9:39:08 AM
Revit Crashes at Startup
Wed, Apr 28, 2010 at 7:26:51 AM
Revit TotD - Linked Model Visibility, part 1
Mon, Feb 15, 2010 at 9:08:56 AM
Page generation time: 1.2509
