Forums >> General Discussion >> Revit Project Management >> Creating Curian Walls
Sat, May 9, 2009 at 3:01:59 PM | Creating Curian Walls
albertstwrt
4 Stars: 8 Votes
Can anyone tell me how to install, a grid system in this mass? Because the snaps tool, don’t seem to be working on the mass object.       But they are working on the other mullions, with in the drawing. I would like to set the mullions on a (45 degree angle), to create a diamond affect to the lower portion of the curtain wall. I have deleted the top portion of the wall, and kept the bottom. Can this be problem, why the snap are not working?
Sun, May 10, 2009 at 5:35:24 AM | Creating Curian Walls
4 Stars: 205 Votes
In Revit 2010 with the new "Conceptual mass" you can create that but in 2009 you only can put the angle in the flat surfaces
Mon, May 11, 2009 at 12:18:51 AM | Creating Curian Walls
albertstwrt
4 Stars: 8 Votes
Typhoon: I’m using Revit Architectural 2009 at this time. Is there some way I can make, (custom mullion) for this wall? I try going into my south elevation and setting the grids there , but the snaps still aren’t working. So I’m asking, can I create a (custom mullion) for this wall?
Mon, May 11, 2009 at 6:57:15 AM | Creating Curian Walls
You know albert, sometimes it really is annoying when someone really doesn't listen.  Please re-read Typhoon's post.
Mon, May 11, 2009 at 8:28:22 AM | Creating Curian Walls
4 Stars: 205 Votes
Yeah WWhub, some times they are...
Albert I'm thinking..... right now i don't have here Revit but I take a look later to see how can we do something like that in 2009 BUT not using Curtain Grids, i'm thinking in other way and i need time....
Mon, May 11, 2009 at 9:09:55 AM | Creating Curian Walls
albertstwrt
4 Stars: 8 Votes
WOW!!! annoying !!  I'am__SORRY!
But I'm trying to get any Mullion patternig in the design right now. Can I get some "HELP PLEASE"????????????????
Mon, May 11, 2009 at 9:15:38 AM | Creating Curian Walls
So are you talking about mullion pattern or mullion profile?  There is a difference.  Typhoon has answered your question on pattern.
For mullion profiles - look in your H E L P using "profile" as your serach and you will find the full process for creating profiles for mullions and setting them.
Mon, May 11, 2009 at 3:43:49 PM | Creating Curian Walls
4 Stars: 205 Votes
There it is, in Revit 2009, NOT CURTAIN GRIDLINES....
Mon, May 11, 2009 at 3:54:47 PM | Creating Curian Walls
Well, I knew you could do it Typhoon but now you are going to have to create one of your magical Jing tutorials.   I was thinking in-place sweeps but retangular profiles would be hard to keep normal to the surface... it appears that if that is what you did, you cheated and used a round profile.  :-)
Mon, May 11, 2009 at 4:29:45 PM | Creating Curian Walls
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I strongly suggest if you really need to do this you upgrade to 2010.  If you aren't on subscription, then its going to be expensive exerice when you need to upgrade again.
As Typhoon has shown, he has created an in-place family and then in elevation created void diamonds to leave just the sections where the mullions would be.  Then used pick path and a loaded profile for the mullion to create each of the mullions manually.  Unless he has done something different??
As you can see this is a rather convoluted process and doesn't lend itself well to later design changes as there would be a lot of rework.  This would be avoided in RAC2010.
Regards,
Chris.
Mon, May 11, 2009 at 4:52:44 PM | Creating Curian Walls
4 Stars: 205 Votes
"Well, I knew you could do it Typhoon but now you are going to have to create one of your magical Jing tutorials."  - I DO THAT LATER, IF I HAVE TIME TOO....
"I was thinking in-place sweeps but retangular profiles would be hard to keep normal to the surface... it appears that if that is what you did, you cheated and used a round profile" - THERE IT IS WITH RECTANGULAR MULLIONS, in the begining i post with circular mullions because i think the shape of the glass it's the most appropriate, but like you know we can put the profile we want, so IT'S DONE, it's possible to do BUT NOT with curtain walls and curtain gridlines or mullions, but it's possible with some few extra work, 5 minutes to do it....
Edited on: Mon, May 11, 2009 at 4:53:28 PM
Mon, May 11, 2009 at 9:06:21 PM | Creating Curian Walls
albertstwrt
4 Stars: 8 Votes
Thinks everyone, I appreciate the time you all have giving me.    I will let you all know how I made out.
Mr. Spot my computer has only (2GB of Ram, and a DUO Core 2.00 GHZ Intel). I believe to run 2010 you need 3mb of RAM
Mon, May 11, 2009 at 10:53:02 PM | Creating Curian Walls
#13
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Although that is a little low on the specs that system should run Revit 2010 fine.  With only 2GB Ram though you would find that it may become a little unstable on files nearing the 100MB mark.  Revit 2010 doesn't require any more grunt than 2009 with the exception of up to date video drivers...
Although I strongly suggest you trial any new version for a while before updating officially!  This way you can identify any potential instability issues in advance.
Edited on: Mon, May 11, 2009 at 10:54:15 PM
Regards,
Chris.
Thu, May 14, 2009 at 2:44:30 PM | Creating Curian Walls
#14
4 Stars: 205 Votes
WWhub, there it is the videos, sorry for my bad english, but I bet (no I have sure) I speak better Portuguese, Spanish and French than you, LOL....
1º Video:  http://www.megaupload.com/?d=8BS6S1CG
2º video: http://www.megaupload.com/?d=M9M4J7KU
Thu, May 14, 2009 at 7:41:17 PM | Creating Curian Walls
#15
albertstwrt
4 Stars: 8 Votes
That’s ok. I appreciate the time you all has given me. Tyhpoon I’m going to the site now, to check out the video.  Here is my model.
Creating a roof that slopes with the walls
Sun, Feb 27, 2011 at 2:35:54 PM
Creating Curtain Wall Schedules
Thu, Sep 14, 2017 at 11:59:47 AM
creating walls completely (help)
Mon, Feb 16, 2004 at 7:45:43 AM
14
Need HELP creating walls from mass
Wed, Nov 7, 2012 at 6:35:21 AM
Curved Angled Glass Walls
Thu, Jan 20, 2011 at 3:01:49 PM
Page generation time: 0.6395
