Forums >> Revit Building >> Technical Support >> Extrusion visibility
Tue, Apr 28, 2009 at 3:29:14 PM | Extrusion visibility
beckyl
I edited the standard column family to add solid sweeps at the top and bottom. Now when I load this new family into the project, the extrusion (column itself) is not visible in any of the views but the sweeps are. Visibility is turned on for the extrusion in all views. ..?
Tue, Apr 28, 2009 at 3:34:19 PM | Extrusion visibility
travistlo
5 Stars: 2 Votes
did you attached the sweeps to the top reference plane correctly? is the column too short, but the sweep is up in the air? Check the elevations to see what it looks like. Check all the heights, make sure to flex the family in the editor before you load it into the project.
Chatting it up on gmail - travistlo.j@gmail.com
Void extrusion family visibility
Fri, Apr 22, 2022 at 7:57:52 AM
EXTRUSION YES/NO PARAMETER
Mon, Apr 28, 2014 at 4:04:36 PM
11
re-joining (?) cut extrusion with extrusion
Tue, Apr 17, 2007 at 10:26:27 PM
void extrusion not cutting solid extrusion
Fri, Oct 10, 2008 at 3:47:43 PM
Void extrusion not showing in section cut
Thu, Jun 12, 2014 at 12:36:06 PM
Page generation time: 0.1327
