Forums >> Revit Building >> Technical Support >> Revit Line Colors
Tue, Apr 28, 2009 at 1:42:27 PM | Revit Line Colors
mark2001
When I import autocad into revit I am stuck with line colors I don't know how to change.  Where can I change them??
 Sincerely,
 Maor
Tue, Apr 28, 2009 at 1:45:37 PM | Revit Line Colors
4 Stars: 205 Votes
Did you try in "Object Styles"???
Tue, Apr 28, 2009 at 2:25:45 PM | Revit Line Colors
mark2001
yes and no luck,  they all show black??
but I still have color in the view
Tue, Apr 28, 2009 at 2:52:55 PM | Revit Line Colors
4 Stars: 205 Votes
What??? in your view you have your lines (cad) with colors and in the "Object Styles" all of that Categories (layers) are in black??? is that ???? when you import that cad file you choose "Preserve Colors"???
Edited on: Tue, Apr 28, 2009 at 2:53:22 PM
Tue, Apr 28, 2009 at 9:08:39 PM | Revit Line Colors
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Hi mark2001, are you sure that when you draw your lines in AutoCAD you draw 'em By Layer and not By color. In the image attached you can see that all my imported drawing is in black except the numbers of the dimensions that are in green because I have them By color and not By Layer, so check this....
Setting Line Colors to print in grayscale
Wed, Feb 21, 2007 at 10:21:49 AM
Area plan not printing walls and doors below colors
Sat, Mar 14, 2015 at 1:26:36 PM
Colors and Printing
Thu, Jul 19, 2012 at 10:11:31 AM
Exporting Revit to AutoCAD - Getting line colors 'right'
Thu, Apr 9, 2015 at 7:29:49 AM
linweweight asignments to autocad colors
Thu, Jul 14, 2005 at 11:26:18 AM
Page generation time: 3.7360
