69 Users Online (67 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Constructing a building
Sat, Apr 25, 2009 at 4:11:56 AM | Constructing a building
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
does anyone know how to- or even heard of- constructing
a building that was designed by someone else who used
a program to create a wireframe- for example sketchup
or 3ds?
i already found out how useless it is importing one of
those wireframes into revit because they are never
accurate enough to use for building- even if they
will come into revit at all..
not only that but they will never cut into sections
and you can't see lines on the inside.. they sure
don't "explode" unless they explode your program
into crashing..
all they ever do is view from the top front and sides as one
big bunch of useless lines..
i found out that most of those wireframe models
will export to DWF and they can be broken up into
parts you can see and measure in there.. and then i'm
thinking somehow to save them as images to
import into revit for tracing or something..
it's not only sketchup and 3ds- there are dozens
of modelling programs that artists use to create
architectural concept models..
i'm wondering if anybody really knows a practical way
to get these wireframe concept models into revit
for construction? i've heard so many wild ideas
but i don't think many know how to do it..
someone please find an answer to this because
this is not just a how-to-do- a certain operation-
this is a major purpose of revit for architecture..
it's true revit finally has a better design/massing component
but not everyone who uses revit is an artist/designer-
and revit is really more about producing construction
documents and a model to inspect prior to starting
the CDs than concept design..
Constructing a new template
Tue, Dec 4, 2012 at 6:25:33 AM
Moving a Building
Wed, Apr 30, 2008 at 5:49:59 AM
Wall types
Thu, May 31, 2007 at 3:05:12 PM
Should I use wall faces?
Fri, Nov 20, 2015 at 4:06:29 PM
Stepped Roof with Overhand
Wed, Oct 23, 2013 at 4:35:15 PM
Page generation time: 0.9867
