Forums >> Revit Building >> Technical Support >> Radius Masking Region for a panel?!
Fri, Apr 24, 2009 at 2:24:12 PM | Radius Masking Region for a panel?!
cwood09
I am having troubles masking this panel out in side / front & back views, because the panel has an adjustable angle control on it and also a radius control. I'm kinda stumped as to how to go around setting something up that would mask it out correctly in the side/front & back views if you are able to adjust the angles/radius control.
Sun, Apr 26, 2009 at 9:57:27 AM | Radius Masking Region for a panel?!
Sorry but your question is unclear.  When we hear masking, we think 2D.  A masking region is 2D and view specific - should not be a problem.  So please clarify.
Masking Region Fill Region Problem
Mon, Mar 10, 2008 at 11:06:24 AM
Masking region at section callout head.
Tue, Jul 30, 2013 at 1:43:26 PM
3D CAD import Part and masking region
Sun, Sep 14, 2014 at 2:36:26 PM
Masking Region doesn't seem to be masking
Thu, Mar 17, 2016 at 10:59:36 AM
Masking region in roof plan
Tue, Feb 24, 2009 at 3:14:03 PM
Page generation time: 0.4836
