Forums >> Revit Building >> Technical Support >> Revit Problems
Tue, Apr 21, 2009 at 1:13:43 PM | Revit Problems
ALEROBER
Anytime I am in my second floorplan mode it will not let me use railings, stairs, or anything of that nature. It tells me the work plane is not in the right view and tells me to go to tools and change this but it will not let me. Someone please let me know.
Tue, Apr 21, 2009 at 1:19:46 PM | Revit Problems
I DON'T KNOW WHAT YOU MEAN BY "SECOND FLOOR PLAN MODE".... DID YOU CREATE A FLOOR PLAN VIEW FROM THE LEVEL?  IF SO, THERE IS NO NEED TO SET THE WORK PLANE AS REVET DEFAULTS TO THE LEVEL.
Wed, Apr 22, 2009 at 8:31:15 PM | Revit Problems
ALEROBER
I just mean when I click level two on my plan views it tells me to pick a plane. I know it usually defaults but this is an unusual circumstance.
Revit Print Problems - UPDATE
Fri, Sep 2, 2016 at 1:44:13 PM
BE AWARE .... REVIT problems with mirroring
Tue, May 22, 2007 at 12:43:54 PM
Revit Structure 3 & Kip 8000 plotter problems
Tue, Jan 22, 2008 at 11:15:49 AM
Printing problems in Revit
Wed, Sep 28, 2016 at 7:06:00 AM
REVIT 2008 - How to avoid Problems?
Sat, Mar 22, 2008 at 8:47:05 PM
Page generation time: 1.7310
