Forums >> Revit Building >> Technical Support >> Textile Rendering Problem
Mon, Apr 20, 2009 at 3:36:06 AM | Textile Rendering Problem
lbuilt20
Hi,
I am having a problem getting an imported textile material to render - I added the material to an object in the family editor, and it appears in the basic 3d model when uploaded into the project - it's just not showing up in a rendered image. Any help would be greatly appreciated! I am still struggling to learn the ropes...
Thanks!
Laney
Mon, Apr 20, 2009 at 4:00:27 AM | Textile Rendering Problem
4 Stars: 205 Votes
In your project, go to settings>materials and check where is the material you create in the "Family editor", then see if it's the material/texture you want for object, if no (i'm sure it's not) change them....
Wed, Apr 22, 2009 at 12:06:31 PM | Textile Rendering Problem
lbuilt20
Thanks, that worked.
Transparent textile in rendering
Thu, Jan 6, 2011 at 8:43:04 PM
Rendering materials within components
Mon, Apr 24, 2006 at 1:49:32 PM
Revit 2009 Rendering Problem(Black screen) [ 1 2 ]
Mon, Apr 1, 2013 at 2:45:28 PM
27
Rendering Problem
Wed, Feb 6, 2013 at 1:41:48 PM
How to create surfaces in a new family
Fri, Aug 5, 2016 at 10:22:41 AM
Page generation time: 1.7845
