Forums >> Revit Systems >> Technical Support >> 2D plan view pipe fittings and accesories
Sun, Apr 19, 2009 at 5:21:32 PM | 2D plan view pipe fittings and accesories
IsItFast
How do I tell Revit not to draw these items in plan view. for my pipe rises I'm getting   -------O  instead of   --------O like I'm used to in ACAD. The symbol that is generated looks like an 'up tee' not a rise. my project manager is going nuts because of this. Also I don't want to see the old school fitting marks either, you know a dash on either side of the tap.
Much thanks to anyone with the answer or information leading to the correct fix for this.
Sun, Apr 19, 2009 at 10:59:47 PM | 2D plan view pipe fittings and accesories
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I haven't used Revit Systems as yet.  But I'd imagine if you edit your pipe riser symbol family to have a masking region it will conceal the line.  I'm taking a stab in the dark as to how it works here...
Regards,
Chris.
Pipe Fittings move during Synchronize
Wed, May 9, 2012 at 1:32:03 PM
How to get pipe fittings to appear as simple pipe lines?
Thu, Mar 20, 2014 at 4:40:08 PM
12
Stumped on why window selection or crossing selection wont pick pipe fittings ?
Sat, Jun 1, 2024 at 1:44:16 PM
Pricing Pipe Fittings
Tue, Sep 14, 2010 at 3:10:59 PM
Parametric Pipe Fittings Family Modelling Problems
Fri, Jan 12, 2018 at 3:44:30 AM
Page generation time: 0.8653
