Forums >> Revit Building >> Technical Support >> Roof Drains
Thu, Apr 9, 2009 at 3:51:13 PM | Roof Drains
revit7777
I am trying to insert a roof drain into my mechanical drawing. I am using revit mep 2009. When I click the plumbing tab, then plumbing components, then load and go to imperial library, and plumbing fixtures, and click the roof drain, it just goes back to the last thing selected in the list and won't let me put the roof drain in. Why is this? The closest thing I can get is a floor drain which isn't going to work.
Thu, Apr 9, 2009 at 4:00:43 PM | Roof Drains
Did you load a detail component or a model component.  Detail components are placed from the drafting tab.  Model components from the model tab.
Thu, Apr 9, 2009 at 4:08:44 PM | Roof Drains
revit7777
How do I tell the difference? I tried it from the drafting tab as well, but I get the same result.
Roof Drains
Mon, Sep 11, 2006 at 11:33:11 AM
Roof Drains- Architecture 2008
Wed, Sep 19, 2007 at 5:00:03 PM
Adding skylights and slopes to a roof
Thu, Jul 12, 2012 at 8:33:07 AM
revit roof slopes
Tue, May 6, 2014 at 10:19:05 AM
Flat roof and a curved wall
Tue, Nov 20, 2007 at 9:56:42 AM
Page generation time: 0.4572
