21 Users Online (19 Members):
Forums >> Revit Structure >> Technical Support >> Losing information when changing scale
2 Posts No Rating |
We originally started a project at 1/8" = 1'-0" the architect requested metric so the scale was changed to 1:100. when I changed the scale all of my section cuts and detail lines disappared. Any suggestions on how i can get this information back? This error was shown Error message Elements None of the created elements are visible in Structural Plan: FIRST FLOOR PLAN View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings. View "Structural Plan: FIRST FLOOR PLAN" : Lines : Detail Lines : id 260172 I didn't change anything other then the scale in this file. The detail lines are visible when i try to reveal the elements but when I select unhide nothing happens. Any ideas?
go back to you original scale 1/8"=1'-0" then select the items that disappear in 1:100 scale, then go to element properties, there change the scale where it says "hide at scales coarser than". You probably have it at 1/8"=1'-0" make it lower than that. let me know if it works for you.
2 Posts No Rating |
Thank you Manny, that did work for the section cut marks.
Parameter formulas losing calculated values |
Wed, Jun 17, 2015 at 2:23:19 PM
changing scale in sections for revit 2013 |
Mon, Oct 5, 2020 at 6:48:55 AM
Changing the scale of a Bump image for rendering |
Mon, Sep 26, 2016 at 1:03:41 PM
changing scale |
Mon, Feb 14, 2011 at 6:58:19 AM
changing the scale of my room and area tags with the scale of my area plan. |
Fri, Oct 22, 2010 at 10:38:38 AM
